MIDI compatibility with Boss drum machines
tonyrobot
Post by tonyrobot » Fri Jan 11, 2008 1:50 am
I'd like to use my Boss DR-670 to MIDI-trigger a Micro-Korg. Is this even possible? It seems like it's not, because the Micro-Korg only recognizes channels 1-16, and the DR-670 only recognizes channels 17-32.
I tried MIDI-triggering the Micro-Korg with my Boss DR-5 as well, because it recognizes MIDI channels 1-16 just like the Micro-Korg. I set up everything according to the instructions, but they're not communicating.
Are these machines just not compatible, or am I doing something wrong here?
Synthazaiser
Gear: B3, CP-30, DX7, Casiotone MT-210, Axxe 1, EPS-1, Promars, MC-202, TR-606
Post by Synthazaiser » Fri Jan 11, 2008 2:35 am
Most MIDI instruments don't use all their channels at once. Make sure that the Boss is transmitting on the same channel as the Korg is recieving.
Currently have: Baby Grand Piano, B3, CP-30, DX7, Casiotone MT-210, Axxe 1, EPS-1, Promars, MC-202, TR-606
Used to have: POLY-800, TR-505, Techstar TS-306, DX7, ESI-32, Juno-106, DX27, Synthcart, JX-3P, ESQ-M, Mono/Poly, MS2000BR, VX90
cornutt
Gear: 6th
Re: MIDI compatibility with Boss drum machines
Post by cornutt » Fri Jan 11, 2008 4:06 am
tonyrobot wrote:I'd like to use my Boss DR-670 to MIDI-trigger a Micro-Korg. Is this even possible? It seems like it's not, because the Micro-Korg only recognizes channels 1-16, and the DR-670 only recognizes channels 17-32.
I think you're confusing the Roland sysex unit numbers with MIDI channel numbers. There is no such thing as MIDI channels 17-32; they only go up to 16.
Can the Micro-Korg be put into omni mode? That might at least get you started. Once you've demonstrated that your MIDI cables are good and so forth, you can work on getting the MIDI channels matched up.
killedaway
Gear: Electribes x 6
Revolution
Monomachine MKII
microKORG
CS01
& more!
Band: killedaway/allyourblood
Post by killedaway » Fri Jan 11, 2008 6:09 am
i used to use my DR660 for this, so i know it can be done. it's just a matter of ensuring your MIDI settings are correct.
1.5.9.13
1.5.9.13
t.o.t.s.
Post by t.o.t.s. » Fri Jan 11, 2008 6:46 am
it can be done. I also use my 660 as a trigger for several things.
totsland.net / chvad.com / 8bitaudio.net / darksonus.com / invisiblerecords.com
Moog LP, SCI Six-Trak, Roland RS09, Crumar Performer, PAIA Fatman, Korg EX-8000, Waldorf µwaveXTK, Novation K-Station, XioSynth, KS4, Alesis Ion, Korg ER-1, Etherwave, MidiNES
