Roland drum machines triggering korg PolySix Arp.
bionary
Post by bionary » Thu Jan 17, 2008 4:51 am
Can the trigger out from a Roland TR-707, 606 or Boss DR-110 act as the clock source for the arpeggiator on the Korg PolySix?
Altitude
Post by Altitude » Thu Jan 17, 2008 12:52 pm
It should, just write in notes (16ths, 8ths, etc) and it will advance the arp for every pulse it receives
plus321
Post by plus321 » Thu Jan 17, 2008 2:44 pm
Since the Mono/Poly uses S-trig on the arp clock, then I would assume that the Polysix does as well.
You will need to make a cable (or mod your machine) to accept v-trig (from Roland machines).
This picture says it all.
http://www.synthesizers.com/moog_trigger-convert.jpg
Europe Endless
Gear: Minimoog model D, Prophet 5 3.3, MultiTrak, Juno-60, 3xPolysix, Trident MkI & MkII, DW8000, DX7IIFD, KX88, and DIY Digisound SSM-based mono.
Post by Europe Endless » Thu Jan 17, 2008 4:48 pm
plus321 wrote:Since the Mono/Poly uses S-trig on the arp clock, then I would assume that the Polysix does as well.
Your assumption is correct. Just checked the schematic and yes - the Polysix uses S-trig
bionary
Post by bionary » Thu Jan 17, 2008 10:11 pm
Is it possible to make the cable shown in the above link with 1/4 inch on one end and 1/8 inch on the other? The PolySix doesn't use the Jones connector.
OriginalJambo
Gear: Check my sig
Post by OriginalJambo » Thu Jan 17, 2008 11:09 pm
Well the Kenton I have seems to work for both my PolySix and JX-3P, so I'd assume that it would.
plus321
Post by plus321 » Thu Jan 17, 2008 11:20 pm
bionary wrote:Is it possible to make the cable shown in the above link with 1/4 inch on one end and 1/8 inch on the other? The PolySix doesn't use the Jones connector.
Yeah, you can put whatever you want one the ends of the cable. Just make sure tip goes to tip (signal) and sleeve to sleeve (ground).
