How many mega amps is too many?
supermel74
Post by supermel74 » Mon Apr 14, 2008 2:03 am
Is it ok to use a 9 volt 1000ma power supply with a unit that calls for 9 volt 200ma? I tried it, and it worked fine, but will this cause damage if used over a prolonged period?
Post by Stab Frenzy » Mon Apr 14, 2008 2:34 am
You mean milliamps. :D
The current rating on a power supply just tells you what the maximum output it can handle is, if you use it on a device that doesn't need as many then it just won't output as much.
So basically, it's fine.
V301H
Band: The Characters
Post by V301H » Mon Apr 14, 2008 2:35 am
"ma" stands for milliamps. It's okay to exceed the rating as the unit will not draw more power than what it needs. For a unit rated at, say, 500ma you wouldn't want to use a 200ma adaptor. You can exceed the ma rating without any problem, but don't go under or the unit may not work properly.
supermel74
Post by supermel74 » Mon Apr 14, 2008 2:41 am
Cool. Thanks guys
hyphen nation
Gear: boxes that make noises
Post by hyphen nation » Mon Apr 14, 2008 6:38 am
I thought this was going to be a post about marshall and bogner stacks...
supermel74
Post by supermel74 » Mon Apr 14, 2008 7:33 am
hyphen nation wrote:I thought this was going to be a post about marshall and bogner stacks...
:lol: Is this too many?
eeprom_one
Post by eeprom_one » Mon Apr 14, 2008 7:38 pm
the level current on the transfromer o adapter must be always higher than the machine needed
if you need 200mA is very good for your adapter what be higher 1000mA=1Amp.
doesn´t matter, never break :wink:
Analog powA!
http://www.myspace.com/spaindeejayscom
http://www.myspace.com/eepromone
2xElectribes rmkII (drummachine+synth) + Tg-500 Yamaha (tone generator). Comming soon: elektron monomachine mkII
