mine drum machines are about 6-7 meters from Computer ...what would be clever solution????
1. to connect Unitor 8 MkII with 7 m cabel USB and 1 meter MIDI to each machine
2. to connect 7 meter PS2 cabel from stealth port to Unitor 8 and then to 1 meter midi kabel
3. direct connection with 8 Meter MIDI cables ..need 7 of them
or
4. 7 meter of midi to A880 midi thru ( I have hat midi thru box) and than 1 meter midi cabels
I run Logic 6 pro and 8 on G4 with 3 Unitors ..this should be fourth
Help needed here
Connecting Drums to Comp logic unitor???????
