Hi,
As the Rland alpha Juno 2 does not have knobs there are many people who does it across the PG-300. I have seen to control these SYNTH with a BCR200 of behringer !!
In my case ,I have a Roland sh32, so ...
¿ It would be possible to control the juno 2 with the sh32, doing the function of a PG-300 ?
tanks !!!!!!!
Control Roland alpha Juno 2 with sh32; ¿possible ?
The BCR2000 has learnable sysex for each rotary control, which means you'd have to either program it first or get a sysex template. According to the SH-32 manual appendices, it only sends and transmits fixed CC's and system exclusive messages for its functions. The alpha Juno does not use any CC's and has its own set of custom sysex like any other device would. ie. no.
--Solderman no more.
- Gear: Roland: Alpha Juno 1, HS-60, JX-3P
Yamaha: CS01, AN1x, TX81Z
SCI Pro One
DSI: Tetr4, Mopho Keyboard
Casio HT-700
Vermona DRM Mk. III
Jen SX1000 - Band: British Airwaves
You wanna control the Alpha Junos? It's all sysex so it has to be programmed just for the AJ. You can use the PG300 if you are rich or, if you are like me and poorer then use a controller. In my case I use the Novation Remote SL Zero as it's got the screens to keep track and you can program it right in unit itself. I then use the same template and adjust for different sysex codes for different synths.
In short - grab a Remote SL Zero for £100 and program in the AJ sysex codes. Then go mad, it really is a great synth when given that amount of easy control!
Oh and no, my SH32 won't directly control it. You could use MAX or other software to effectively translate between the CCs and sysex but the layout of the SH32 doesn't correspond to the parameters of the AJ (no chorus speed for instance) so get a controller - more useful in the long run too.
- Sexor
- Gear: Prophet6, Jupiter-7, MS25, Juno-50, TR-303, Rhodes 63
I got the PG-300 a few months ago.... found it extremely underwhelming (stepping filter etc...). So I sold it and got myself a Juno-106 for the same amount of money (!!)
I still have the Alpha but I use a program called EZalpha to program it. Muchmuchmuch cheaper 8)
You might consider getting the BCR2000 as a cheap hands-on way to program it... As mentioned earlier, the SH-32 cannot act as a sysex programmer so it won't work.
Monkey business since 2007!
- stikygum
Did you make a AJ template on the SL? Care to share?gunark wrote:You wanna control the Alpha Junos? It's all sysex so it has to be programmed just for the AJ. You can use the PG300 if you are rich or, if you are like me and poorer then use a controller. In my case I use the Novation Remote SL Zero as it's got the screens to keep track and you can program it right in unit itself. I then use the same template and adjust for different sysex codes for different synths.
thanks for all !!! great people at this forum !!
i dont speak english so well because i am from Spain but i´ll try to do it.
I am searching for Pads or ambient presets to load into the Juno 2, and i want to know 2 thing about it:
1- Where can i get them
2- how can i send them to the alpha juno
thanks again !!!!
thanks again !!!!
