problematic linn drum
- supercluster
So i found someone who wants to sell me there midi outfitted linn drum. i just checked it out, and i couldnt get any sounds out of the thing. tried both channels. do you NEED to run it in stereo to get sounds out of it? doesnt make sense. the other notable problem was that the lights stayed on and didnt blink when buttons were pressed. Also- the play/stop button was always on. (red) all the buttons with led's were constantly 'on'.
anyone have any idea what the problem might be? or how much A fix might be ? thanks!
oh, and its an LM-2.
Doepfer A-100, MPC1000, Alesis Ion
Roland Re-20, Moog MF-105, Moog MF-102, boss me50-b
For sale: Yamaha RS7000, Korg Kontrol49
- hfinn
- Expert Member
- Gear: http://soundcloud.com/heath-finnie
Does it have the patches loaded in? If not it won't do much of anything unless you program something...
You don't need to run it in stereo either, as long as you pan the voices the right way.
p.s this should be in the help section...
- supercluster
- Stab Frenzy
- Moderator
- supercluster
i hope its not broken, because if i can get it to work.. dirt cheap!
ive read some accounts of people with linn drums that need 15 minutes to warm up. im sending the guy an email to try letting it warm up for a long period of time. eh..
- hfinn
- Expert Member
- Overgear
- Junior Member
- Gear: AX-73, S3000, MFC42, K5000R, K4r, K1, Nord 3R, MKS-50, Juno-106, JP-8000, CS-10, CS-15, TVS-1, PP SEM(x2), Rogue, Source, Pro-One, P-600, Mopho
It sounds like it's not passing the power on self test. When you turn it on, it flashes all the lights and the the numerical displays read "00" on the upper and "0.0" on the lower. It only holds for a second and then clears. It sounds like it is stuck there. Only the pattern light and the lower display should be lit("11") when it is ready for normal operation. If it doesn't reach this state, it won't do anything.
It could be a midi error. You could try to sending a midi panic(or all notes off) command to it. Maybe it just got locked up. You would think this would be corrected by powering it off/on, though.
It may be a slave issue like Stab mentioned. Mine doesn't have midi so I don't really know how that operates. When you sync by CV, you hit the Ext Sync pad above Play. You then hit Play. At this point Play and Ext Sync should be lit but you will not hear anything. Once it receives a sync signal it starts to play. It may respond the same way with midi sync.
I'd suggest opening it up. It may not provide any answers but it only takes a few seconds. Just 3 screws on the front. It could be battery leakage. Lets hope not.
I hope this helps.
I hope this helps.
- nathanscribe
- VSE Review Contributor
It could be that the memory's full of c**p through a battery or power supply fault. In that situation, it needs resetting. At work at the mo, and can't remember the procedure offhand, but you could download the manual and have a look. It's in there - just a couple of button-pushes. Linndrums seem particularly responsive to power issues; mine acted weird for a while until I used a reliable supply. Happy as larry now.
It could also be something daft like a bad connection or ill-seated IC. At least the Linn batteries are not on the main board, so if they do leak you probably won't fry anything precious.
If it's cheap enough, you could buy it anyway, and if the MIDI's problematic, you could always remove it and sync the Linn via it's clock jack instead (it wants a 48ppqn pulse).
- supercluster
hah.. not the first message i've received like this...atkbg wrote:You! You! You bastard!
Did you get the ESQ-1, too?
the guy lives less than 5 minutes away from me.
- supercluster
