lag in sound when using microkontrol and Arturia Minimoog
greentmanta
Gear: Korg KP3, Korg EMX-1, Electro Harmonix EH 0400 Mini Synth, Serato
Band: Khoizilla
Post by greentmanta » Fri Jul 25, 2008 4:15 am
I'm experiencing lag between the time that I play a key and hear a sound. Can anyone help me configure this? Same goes for my Arturia Arp2600 and Reason 4.0
Summa
Post by Summa » Fri Jul 25, 2008 4:31 am
Depending on the Computer/OS you use, on Windows I'd say you should use ASIO drivers and reduce Latency Settings/Buffer Size...
Joey
Band: BLUSH_RESPONSE
Post by Joey » Fri Jul 25, 2008 6:23 am
are you running it off of bus power or AC power?
you should always have it plugged into a wall socket if possible, and not bus power.
that will help quite a bit.
other than that it could be that your computer is not fast enough, or you have something wrong with your ASIO driver settings.
http://wearereplicants.com
greentmanta
Band: Khoizilla
Post by greentmanta » Fri Jul 25, 2008 6:31 am
Summa wrote:Depending on the Computer/OS you use, on Windows I'd say you should use ASIO drivers and reduce Latency Settings/Buffer Size...
Got it thanks! It worked after reducing the latency however it distorts when I lower the latency very low. How can I obtain the ASIO driver? I changed my preferences to ASIO and did not sound. It only works through my diretcx. I'm using Vista if that helps.
Post by Stab Frenzy » Fri Jul 25, 2008 6:35 am
greentmanta wrote:I'm using Vista if that helps.
There's your problem.
Summa
Post by Summa » Fri Jul 25, 2008 12:11 pm
Well, Vista isn't that bad, just pretty resource hungry and driver situation isn't perfect yet...
Summa
Post by Summa » Fri Jul 25, 2008 12:16 pm
What soundcard/audio device are you using? If it's an onboard sounddevice it might help if you use ASIO4ALL...
http://www.asio4all.com/
Is your powermanagement set to high performance, since on a Speedstep/Powernow/Cool'nquiet system this is influencing the performance/processor speed of your system...
Post by Stab Frenzy » Fri Jul 25, 2008 4:54 pm
Summa wrote:Well, Vista isn't that bad, just pretty resource hungry and driver situation isn't perfect yet...
Well the ASIO driver not working at all is a bit of a problem. ;)
Summa
Post by Summa » Fri Jul 25, 2008 11:24 pm
I can't confirm this, ASIO works fine on my Vista Computer...
