Sequential Circuits MULTI-TRAK low sound level!!!
Eugene Tongue
Post by Eugene Tongue » Sun Sep 21, 2008 2:20 pm
Hi! Bought Multi-Trak on ebay. The output sound level is very low even on maximum "Master Volume" on all patches on all outputs. Can this problem be solved or it is okay for all Multi-Trak's? If i increase input gain on the mixer - terrible noise appears. Looks like something is wrong with a signal-to-noise ratio on the synth's output. When I play, it feels, that a dynamic range of the sound produced is very small, according to noise level. Multi-Trak Model 615, Serial #02163. Hope for your help. Thank you in advance.
Bross
Re: Sequential Circuits MULTI-TRAK low sound level!!!
Post by Bross » Mon Sep 22, 2008 3:09 am
I worked on one and noticed the same thing. I don't believe there is a volume calibration trim pot either.
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Post by Maschinengeist » Mon Sep 22, 2008 4:51 am
You've got quite apparently a semi-dead op-amp at the output. So no, it's not normal and it should be fixed. I'd have to dig up my service manual to know which one but a tech should find it quickly by doing some routine tests.
MuzikElektronix.com
Help? See TechZone
Parts? email!
Sorry, they aren't free
Eugene Tongue
Post by Eugene Tongue » Mon Sep 22, 2008 2:36 pm
Thank you, Maschinengeist, for your reply! Anyway if you can tell anything about that dead op-amp I'll try to fix it if I need to replace it with the new one only. I have some soldering skills, but I can't do routine tests myself :? :D Regards!
Post by Stab Frenzy » Mon Sep 22, 2008 3:10 pm
Try opening it up and seeing how many exclamation marks there are. There should be at least three, any less and that could be the source of your problem.
Eugene Tongue
Post by Eugene Tongue » Mon Sep 22, 2008 4:24 pm
Sorry, Stab Frenzy, did not understand your idea :) exclamation marks should be written on the PCB? What does it mean? Thanks.
Post by Stab Frenzy » Tue Sep 23, 2008 3:01 am
Don't worry, it was a poor attempt at humour. :D
