No Sound From My Micron
nsbhp2
Gear: Roland JV-1080, Korg Legacy Collection, the impOSCar, Korg DS-10, MicroKorg, Roland JP-8000, Casio CZ-1000, Korg Monotron, Korg Kaossilator
Post by nsbhp2 » Fri Oct 10, 2008 1:55 am
Hey all! Well, after not hearing from UTEPguy about my missing AC Adapter for the Micron I bought from him, I broke down and went to Radio Shack and got a generic one. The adapter works fine (9V, 1.5A same as the OEM), the synth powers up, but NO sound. Nothing from the headphone jack, nothing from either channel to my amp (and YES, the volume is turned up :) ). So I checked the setup, all cool there with local kybd cntrl, etc.... I even did a hard reset to factory setup, and no dice :? . So, anyone have any ideas? I REALLY hate to think I pissed away $265 for a non working synth. ANY help would be greatly appreciated!
Peace!
Scott
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Re: No Sound From My Micron
Post by Maschinengeist » Fri Oct 10, 2008 4:26 am
Assuming that the cables/headphones are alright and that no parameters are set to "0", I'd be tempted to conclude to op-amps problems. Microns & Ions are known for that defect. Replacing them could be tricky since they are nor "thru hole" but SMD (surface mounted. Therefore tiny. Better be good with a soldering iron).
I don't have my service manual anywhere nearby so I cannot say look at this or that precisely.
MuzikElektronix.com
Help? See TechZone
Parts? email!
Sorry, they aren't free
Altitude
Post by Altitude » Fri Oct 10, 2008 6:44 pm
Did you make sure you got the right type of transformer? i.e. AC to DC vs AC to AC
nsbhp2
Post by nsbhp2 » Fri Oct 10, 2008 11:17 pm
Altitude wrote:Did you make sure you got the right type of transformer? i.e. AC to DC vs AC to AC
Altitude, which would I need, as the Micron is marked 9V AC at the plug (on back of synth), and the adapter is 9V DC output. I guess I should have paid more attention while I was at the Shack.
Peace!
Scott
Post by Stab Frenzy » Sat Oct 11, 2008 3:11 am
Peace!
Scott
That's your problem then, the input needs to be AC or it won't work. How did you check the setup/local control on if you were using the DC supply? I seem to remember that using a DC supply on a Micron made the lights turn on but nothing else, maybe I just remember wrong.
Anyway, get yourself a 9VAC supply and it'll work fine.
nsbhp2
Post by nsbhp2 » Sat Oct 11, 2008 3:20 am
Peace!
Scott
Other than not producing any sound, everything else seemed to function fine. I was able to access all menus and such. Now, I have another question. Why is it that all other electronics I have with wall-warts go from AC to DC, but the Micron is the freak and is AC to AC? :?
Peace!
Scott
Post by Stab Frenzy » Sat Oct 11, 2008 4:12 am
Pretty much all Alesis stuff runs off 9VAC, that I've found. If you put in an AC signal it's easier to step it up and down to get different voltages, so you can rectify it and get +5VDC for the digital circuits and get +-9VDC rails for the analogue output section. You get more headroom on the analogue side doing this.
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Post by Maschinengeist » Sat Oct 11, 2008 6:01 am
And also the Ensoniq Fizmo (just to name that one) and many others too. As Stab Frenzy explained quite clearly, working with AC is easier than with DC. It's all a question of design that will push one toward AC/AC adapter and another towards AC/DC adapter. Nothing unusual.
MuzikElektronix.com
Help? See TechZone
Parts? email!
nsbhp2
Post by nsbhp2 » Sat Oct 11, 2008 1:22 pm
You guys ROCK! This is why I love this site so much when I need help. Thanks a bunch! Guess I'll be waiting on Radio Shack's front step at open this morning.
Peace!
Scott
nsbhp2
Post by nsbhp2 » Sat Oct 11, 2008 4:38 pm
Well, no luck at The Shack :( ! All they have is AC->DC models.....So, I did find this online http://www.action-electronics.com/acadapter.htm#Ac. This appears to be correct. Maschinengeist and/or Stab Frenzy care to back me up on this one before I order? I would wait to hear back from Tech Support @ Alesis, but I'm sure they'd want to charge an arm and/or leg for one.
Peace!
Scott
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Post by Maschinengeist » Sat Oct 11, 2008 9:23 pm
9VAC, 830mA (it should be printed near the power socket). A Micron user in here will sure confirm it. 1A will do fine.
MuzikElektronix.com
Help? See TechZone
Parts? email!
Post by Stab Frenzy » Sun Oct 12, 2008 1:03 am
The Micron says 1.5A on the back, but we ran ours off a 500mA SR-16 supply and it was alright except for a lack of headroom. We have a 1.5A one now, much better. :thumbright:
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Post by Maschinengeist » Sun Oct 12, 2008 2:39 am
Excellent! I took my info from the owner's manual. But if Stab says so. More amperage is better than the lack of.
MuzikElektronix.com
Help? See TechZone
Parts? email!
Zamise
Gear: Rollhand P00
Band: Quantum-Source
Post by Zamise » Thu Oct 16, 2008 3:48 am
If it turns out not to be the wall wart adapter, you may need to open her up and check to make sure all the ribbon cables from the buttons, pitchwheel, etc., are securely pressed in. I had mine do similar after I took it apart once, thought I broke it, but took it apart again and resecured all the ribbon cables and it decided to work again. Its a bit of a tough b***h to take all apart and put together to check all those cables, they are on the underside if I remember right, can't get to them by just opening the case, have to get the keybed out and mainboard has to be flipped over too I think, then putting back together #-o
Zam
