Audio In for Juno 6
iamrcb
Audio In for Juno 6
Post by iamrcb » Sun Oct 26, 2008 6:42 pm
Is it possible to modify a Juno 6 to have an audio in?
micahjonhughes
Re: Audio In for Juno 6
Post by micahjonhughes » Sun Oct 26, 2008 10:26 pm
I would say no easy way as there are 6 VCF->VCA paths in the synth. In a mono there is just one signal path, so you put the audio in right before the one VCF. I guess you could feed the audio in to all 6 paths or find a way to make the synth not rotate voices.
hageir
Gear: http://www.geirhelgi.com/
https://soundcloud.com/geir-helgi
Band: Geir Helgi
Post by hageir » Tue Oct 28, 2008 4:27 am
but there actually was a mod for the Polysix to give it an input to the filter..
might be similar to the Juno 6? They're quite similar.. (in a way)
Hossinfeffa
Gear: Roland D-50, MT-32, Korg DSS-1, DDD-1, MS-20, Yamaha FB-01, PSS-560, Akai AX-80, MfB 522, Arturia MiniBrute
Post by Hossinfeffa » Tue Oct 28, 2008 4:33 am
hageir wrote:but there actually was a mod for the Polysix to give it an input to the filter..
Yeah, the Juno-6 at least has an analog filter on it. So if it was done with a Polysix, it seems possible for a Juno.
Well fffff.
atkbg
Post by atkbg » Tue Oct 28, 2008 2:56 pm
Probably should not speak since I don't really know........
Ahh, what the h**l.
There was a mod on the 106 to put audio in place of the noise slider. Done incorrectly, this effectively looses the noise from the signal path. However, could cut the trace, install a switch and have either.
