Yamaha RY30 ! CHANGE BATTERY !
hinotori
Gear: /A1200/CVI/SIXTRAK/
SYSTEM100&100M/CS30/SK1/NORDG2/
Post by hinotori » Fri Nov 28, 2008 5:52 am
so
when i switch on my beloved RY30 it flashes this message
! CHANGE BATTERY !
has anyone done this before ?
im weary to open it up without some advice .
any advice welcome .
many thanks
peace
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Re: Yamaha RY30 ! CHANGE BATTERY !
Post by Maschinengeist » Sat Nov 29, 2008 4:22 am
It takes a standard CR2032 coin type lithium battery (available everywhere). As far as I remember, it is not mounted in a battery holder (ut would be a great idea to had it). The battery & holder are available everywhere (even at Radio Shack).
Straightforward procedure: you only have to desolder 3 solder joints.To resolder, use 60/40 rosin core solder (nothing else). Place the battery like this: the + (engraved on it) facing you so that the negative side is facing the PCB.
BEFORE DOING SO, YOU MUST DO A BACK UP BECAUSE YOU MIGHT LOSE ALL YOUR DATA. THE SRAM MEMORY CAN ONLY BE WITOUT A BATTERY FOR AS LONG AS 5 MINUTES BEFORE ERASING ITSELF.
Please refer to your manual for the procedure or go Yamaha's website to download a free copy.
It shouldn't be difficult at all. But don't forget to save your data before doing anything (or before the battery dies).
MuzikElektronix.com
Help? See TechZone
Parts? email!
Sorry, they aren't free
hinotori
Post by hinotori » Mon Dec 08, 2008 11:16 am
many many thanks for the detailed advice
i will attempt the repair over the coming weekend and report back for the benefit of future ry30 users.
thanks again :)
