polysix tuning issues
sam
Post by sam » Wed Dec 03, 2008 11:32 am
A friend of mine has a polysix ....It takes an hour to tune up.
So has anyone else here had this problem and how can it be solved ect..?
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
Synthaholic
Re: polysix tuning issues
Post by Synthaholic » Wed Dec 03, 2008 2:15 pm
Follow the calibration procedure on this page (click on pages 9-14):
http://www.oldcrows.net/~oldcrow/synth/ ... iserv.html
sam
Post by sam » Wed Dec 03, 2008 7:39 pm
Thank you... :D
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
radek tymecki
Post by radek tymecki » Wed Dec 03, 2008 8:33 pm
If if won't help try to exchange optocoupler. You can find many informations about it on polysix yahoo group :)
sam
Post by sam » Fri Dec 12, 2008 1:24 pm
Update....It's now sticking in tune up mode....All the lights are staying on.
So what chip is related to the auto tune up..?
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
sam
Post by sam » Sat Dec 13, 2008 3:17 pm
The octo coupler is the big chip above the battery....Do these go down often..?
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
sam
Post by sam » Sun Dec 14, 2008 3:13 pm
So...All voltages on the power board check out ok, I have not come across this before.
Even in test mode it stays the same....
Should I replace the optocoupler...?
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
sam
Post by sam » Mon Dec 15, 2008 6:08 pm
FIXED...It was just the voltages on the power board that needed adjusting...
Anyway i will replace the battery..It's the first one i have seen with no leakage.
I need to save it's patches...Has anyone a link to the manual ....?
Or knows how to save....
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
OriginalJambo
Gear: Check my sig
Post by OriginalJambo » Tue Dec 16, 2008 1:04 am
You can save the patches by recording through the To Tape output and onto your computer/a tape. You push a few buttons to initiate the process and then play it back to the Polysix via the From Tape input to restore your patches. You just need to make sure you get your levels right.
For details on how to carry out this procedure refer to the user manual. You can find it here in PDF format.
sam
Post by sam » Tue Dec 16, 2008 8:45 am
Thank you...That's just what i needed... :D
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
OriginalJambo
Gear: Check my sig
Post by OriginalJambo » Tue Dec 16, 2008 4:54 pm
sam wrote:Thank you...That's just what i needed... :D
No problem man. Hope you have more luck than me with that - my Polysix's patch memory is dead.
sam
Post by sam » Tue Dec 16, 2008 7:23 pm
Well...The dump worked with my computer.... :D
OJ...Did your poly have a battery problem....?
Maybe i can help.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
OriginalJambo
Gear: Check my sig
Post by OriginalJambo » Wed Dec 17, 2008 3:40 am
sam wrote:OJ...Did your poly have a battery problem....?
Maybe i can help.
Yup - I replaced the battery as soon as I got it. Before this the synth was totally unpredictable and practically unusable, after everything works as it should, except the patch memory. When I try to save patches it doesn't store them correctly - always messed up sounding.
Any ideas? I think the battery leakage maybe affected the chip that handles the patch memory. :(
sam
Post by sam » Wed Dec 17, 2008 9:16 pm
OK....First..You checked all the tracking around the battery including the chip above (SN74LSO8N)...
You should also change that chip..It's tricky but has to be done.
tell me... 8)
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
OriginalJambo
Gear: Check my sig
Post by OriginalJambo » Fri Dec 19, 2008 1:59 am
sam wrote:OK....First..You checked all the tracking around the battery including the chip above (SN74LSO8N)...
tell me... 8)
I wouldn't know where to start with a multimeter...never mind de soldering a chip! I'll remember that number though.
Not having patch memory on a Polysix isn't a huge deal for me - I'm just glad it works 100% otherwise. :)
