X50 effects problem with cubase
ShadowsWithin
Post by ShadowsWithin » Tue Dec 09, 2008 2:18 am
every time i try to used my X50 Jens lead for a sequence on Cubase the effects on the board don't work and im left with a base lead sound, does anyone else have this problem? it only seems to be the X50.
Re: X50 effects problem with cubase
Post by meatballfulton » Tue Dec 09, 2008 3:00 am
Are you using the X50 in a multitimbral mode?
Because there is only one insert effect in the X50 some voices lose their FX when used in combis and multis. This is a common problem with almost all multitimbral hardware synths.
ShadowsWithin
Post by ShadowsWithin » Tue Dec 09, 2008 9:57 pm
is multitibral combi mode, if yes than no, all sounds i've used so far are program sounds.
