Jupiter 6 help (locked up)
Synthlover
Post by Synthlover » Fri Jan 30, 2009 3:00 pm
I have read that a weak or dead battery could be the cause of my Jupiter being locked up. Would anyone know this for sure and would a new battery clear the lockup problem? I did take a reading and it barley reaches 2 volts. Any suggestions would be greatly appreciated!
I have a Roland Jupiter 6 that powers up but has no sound. Can anyone recommend a tech in the U.S. preferably on the east coast ?
Thanks!
Z
Re: Jupiter 6 help
Post by Z » Fri Jan 30, 2009 4:38 pm
Surely you can find someone near you if you look at the sticky thread of synth techs.
Synthlover
Re: Jupiter 6 help
Post by Synthlover » Fri Jan 30, 2009 7:48 pm
Z wrote:Surely you can find someone near you if you look at the sticky thread of synth techs.
THANKS!
Synthlover
Re: Jupiter 6 help (locked up)
Post by Synthlover » Sat Jan 31, 2009 5:37 pm
Would anyone out there know what the cause may be for a locked up Jupiter 6?
Problem is: I turn it on but I can't switch any of the patches etc. The only things I can turn on an off are the left side controls by the pitch bender. Also it makes no sound.
Any ideas or thoughts to what it could be? I did remove the side plates and 3 top panel screws to take a look inside. I did test the battery and it barley reach's 2 volts. It is the original. Would this and have any affect on the machine being locked up?
Thanks.
Synthlover
Post by Synthlover » Sun Feb 01, 2009 5:55 pm
Bump...
Synthaholic
Post by Synthaholic » Sun Feb 01, 2009 9:33 pm
I'd start with that battery. The voltage should be 3+ volts.
Otherwise, the problem is probably the CPU board, which is the board the battery is on.
fOZf8
Post by fOZf8 » Sun Feb 01, 2009 10:52 pm
this happened to my friends Jupiter 6...or at least it extremely similar. We were able to fix it by sending it a specific control change from the computer. I don't remember if the local was just turned off or what, but I remember the it was a higher cc#, right near the end of them.
Radio Electro(u)nique
Limbik Frequencies
Mindset Studio Music and Media
Mindsetstudios
Steve Jones
Real name: Steve
Post by Steve Jones » Mon Feb 02, 2009 4:01 am
2V is too low....
Synthlover
Post by Synthlover » Mon Feb 02, 2009 11:29 am
Steve Jones wrote:2V is too low....
Thanks guys for the reply's!! Steve, I'm going to replace the battery. Do you think it will unlock it so that I can load the factory settings?
Thanks again.
Steve Jones
Real name: Steve
Post by Steve Jones » Mon Feb 02, 2009 11:36 am
Don't know, there would be a diode in there to keep the battery from charging off the 5V rail to the RAM when the machine is on, and another to prevent the battery from trying to power the while synth when the mains is off, so these would prevent the battery from actually holding down the RAM down, but change it anyway and see if you get lucky. If it doesn't help I will get the service manual out and see what else is likely to be an issue.
Synthlover
Post by Synthlover » Mon Feb 02, 2009 11:48 am
Steve Jones wrote:Don't know, there would be a diode in there to keep the battery from charging off the 5V rail to the RAM when the machine is on, and another to prevent the battery from trying to power the while synth when the mains is off, so these would prevent the battery from actually holding down the RAM down, but change it anyway and see if you get lucky. If it doesn't help I will get the service manual out and see what else is likely to be an issue.
Okay I will order the battery today. I'll keep you posted Steve. THANKS AGAIN!
