Yamaha FS1R + Editor help. midi connection!
Postby krimzin » Fri Apr 17, 2009 8:42 am
:mrgreen:
krimzin
Re: Yamaha FS1R + Editor help. midi connection!
Postby Altitude » Fri Apr 17, 2009 11:27 am
midi in and out of the synth connected to the midi out and in of the sound card
Altitude
Postby krimzin » Sat Apr 18, 2009 12:09 am
:mrgreen:
krimzin
Postby Altitude » Sat Apr 18, 2009 11:46 am
how exactly is everything chained
Altitude
Postby krimzin » Sat Apr 18, 2009 1:59 pm
:mrgreen:
krimzin
Postby GeneralBigbag » Sat Apr 18, 2009 3:47 pm
Sounds like you'll need a midi merge box, since you're wanting to send two signals into the FS1R at the same time.
virb.com/ookpikk
GeneralBigbag
Postby Altitude » Mon Apr 20, 2009 5:58 pm
krimzin wrote:well having the midi from the unit go from out to in to the sound card and out from the sound card to the unit. i only have thru to use now. and thats going to the out of the controller (novation 37sl) or korg Z1
You are connecting two outputs to each other and that does not work. a Thru ONLY takes the data at the midi in and sends it out unchanged. You need to merge the signals. The easy way to do this is to grab midiOX and just soft merge the your controller to the midi out of the soundcard
Altitude
Return to HELP!
Users browsing this forum: lunaquesa and 1 guest
