Poly-61 & Polysix - dead key problem
adie
Post by adie » Tue Apr 21, 2009 9:21 pm
I have disassembled some keys frome my poly-61 and I noticed that conductive material is separating from rubber membrane and this cause contact problems (dead keys).
I'm thinkig of buying ultra-thin copper strips, cut and glue them on the rubber membrane.
Do you have any other suggestions how to fix this c**p?
chipaudette
Re: Poly-61 & Polysix - dead key problem
Post by chipaudette » Sat Feb 27, 2016 10:57 pm
LA Synth Co now sells replacement contact strips for several old synths of this era. Very nice, very easy. Worked great for my Mono/Poly (which uses the same type of keybed as the Polysix...I can't speak for the Poly-61).
http://synthhacker.blogspot.com/2016/02 ... opoly.html
Chip
adamstan
Real name: Adam
B5 DIY polysynth
KORG Poly61
Vermona DRM
Solton Programmer 24
LEMA EDD-5
Post by adamstan » Sun Feb 28, 2016 12:21 am
Poly61 also uses this keyboard.
garranimal
Post by garranimal » Sun Feb 28, 2016 6:13 am
Sometimes dust and debris gets in there.
Sometimes the membrane strip is slightly out of position.
chipaudette wrote:LA Synth Co now sells replacement contact strips for several old synths of this era. Very nice, very easy.
This is the best long term option.
A graphite pencil works in a pinch, but is not a long term fix like replacing the membranes.
The original conductive pads have a very specific ohms resistance. Anything with ohms too low, like copper films or silver conductive pens, will cause key-on bouncing. That's a nasty double-triggering/stuttering of notes.
HideawayStudio
Real name: Dan Wilson
Band: Shortwave
Post by HideawayStudio » Sun Mar 06, 2016 11:46 am
Have a word with Bob at Sounddoctorin - he sells kits made up of tiny carbon loaded pucks for repairing this style of keyboard. The same type of contacts are also found in the Juno 6/60/106 series and can be troublesome.
http://sounddoctorin.com/address.htm
