polysix whats that noise?
- johnwally
- Gear: ESX-1 ,Juno 106 ,EA-1, Polysix, Multiple samplers and didgeridoes guitars , jews harps and bongs
- Band: GO GO KAI
My polysix makes a slight patting sound when i hit the key ,not on all patches but especially on patch B3 .Is this the norm? I have only owned the polysix for a short time and have no other to compare it with. I can tweak the sound down but I would like to now if the polysix is functioning 100% is there away to test this sort of thing?
- brian.only
- Gear: Mono/Poly, Polysix, Crumar Performer, Juno106, Ion, CS01, K Station, DX27,77' Rhodes 88 mk1
Re: polysix whats that noise?
Have you tried adjusting the attack- turn from 0 to 1?
It could be as simple as the envelope setting.
Good luck, in general the polysix is a bit noisy btw.
sell me your KS5!
- pflosi
if you mean that slight click, that is intended on organ patches...
polysixes usually need new batteries, and maybe new op-amps... at least mine could use some new ones...
