old midi controller to USB?
AdamGBB
Post by AdamGBB » Wed Jun 03, 2009 7:42 am
I have a midi controller that is probably older than the invention of usb. Also, it only has a midi out. If I had a midi/usb cable and hooked it up to a computer or something, would the keyboard still be able to control the sound module successfully as if it had midi in?
Also, it seems that all midi/usb cables have 2 separate midi jacks presumably for midi in and midi out (and/or midi thru). As I said, my keyboard at the moment only has a midi out. Would it still function if I plugged only one of the 2 midi jacks into the midi out on my keyboard? If not, what can I do to ensure that it does work?
Sorry if these questions sound retarded, we weren't all born with vast expanses of knowledge of synthesizers and midi :)
Re: old midi controller to USB?
Post by Stab Frenzy » Wed Jun 03, 2009 8:23 am
Yes, you can.
Blue Monster 65
Post by Blue Monster 65 » Wed Jun 03, 2009 8:05 pm
http://www.sweetwater.com/store/detail/XMIDI1x1/
Yes, it will work with just your midi out. MIDI jacks are not set up like complete circuits - they are unto themselves and do not require both "sides" to be connected to work.
Scott
Muhahahahahahahahaha!
extinent
Gear: dxm06 efx mixer (half center piece,dm1001 mixer and inputs
kp1 routed into mixer 1 Vci 100laptop AbletonpM-audiomonitors
flat top Ev mic
Band: n/a
Post by extinent » Thu Jun 04, 2009 7:24 am
I ran into this problem with multiple devices and the easy out is dj io box or m audio fast track. expensive but you can rig anything audio after a you run a mixer into a laptop and audio box. I've ran in and out of an open vcr just to get warped sounds off the vhs tapes to have on file.
somnium silentium
