JX8P Midi Control
JX8P Midi Control
Postby Snarecrash » Mon Jun 08, 2009 11:18 am
Hey,
i'm a proud owner of a Roland JX-8P since saturday. It has an impressive full and warm sound.
I was playing and making patches the whole weekend and just can't get away from the synth. :)
Unfortunaltely the JX8P has no Midi CC's to easily control sound-parameters in my software sequencer,
it's possible with sysex commands though.
What are existing possibilities to control the JX8P sound parameters like VCF cutoff in realtime in my sequencer? Maybe a sysex to CC conversion plugin or something like that?
Thanks,
Mark
Snarecrash
Real name: Mark
Re: JX8P Midi Control
Postby iProg » Mon Jun 08, 2009 12:39 pm
Get the external hardware PG-800 programmer if possible and use with and external sequencer and you will be very satisfied :D
iProg
Real name: Carl
Gear: Prophet-5, Prophet VS, Pro-One, Moog Prodigy, ARP Axxe, Korg PolySix, Roland D-50
Band: ArtWithHeart
Postby Snarecrash » Mon Jun 08, 2009 6:44 pm
I really can't afford to pay twice the price for the programmer as i paid for the JX8P itself,
so this is not an option. When theres an PG800 on ebay people almost kill each other to get it. :violent1:
I'm sure there is some way to control it from my software sequencer.
Snarecrash
Real name: Mark
Postby JNeidlinger » Mon Jun 08, 2009 6:52 pm
Unless you are specifically requesting to be able to automate parameters from your sequencer, you can use this:
http://www.synthzone.com/mschreier/html/pcjx8p.htm
I will have to dig around, but I know I've seen a VSTi Jx-8P controller with full automation capabilities as well.
JNeidlinger
Gear: MS-10, MS-2000, CZ-3000, JX-3P, JX-8P, ER-1, MSQ-700, Prophet-600, Poly-61, x0xb0x, OB-SX, Moog Slayer EX-800, Polivoks Filter, Yamaha GS-2, and on...
Postby Snarecrash » Mon Jun 08, 2009 11:23 pm
To automate the sound parameters from the sequencer is exactly what i'm after.
A VSTi that is capable of doing this would be the best solution, but i'm still searching the net for a plugin
and i had no success yet, so it would be great if you could post a link.
I know PCJX8P already, it's a great program and i think i did some cool sounds already. 8)
Snarecrash
Real name: Mark
Postby Electroluver » Mon Jun 08, 2009 11:35 pm
The JX-8P is such a cool sounding synth. I love the bass, strings, and pads. I've been using the edit slider and tweaking patches and saving them on a C-16 cartridge. It's definitely an underrated synth that has amazing sounds and textures. You can control some parameters through midi (velocity, aftertouch, etc.) It's much more fun to just tweak edit on the fly, so keep your eyes open for a PG-800 or just get used to the edit slider.
Then again...http://www.synthzone.com/mschreier/html/pcjx8p.htm
Electroluver
Gear: MS-20, M-500, Polysix, PAiA 4700, ROL309, C64 MSSIAH, JX8P, K2000J, SY-1010.
Band: DJ NAMELESS
Postby Snarecrash » Wed Jun 10, 2009 9:29 am
JNeidlinger wrote:I will have to dig around, but I know I've seen a VSTi Jx-8P controller with full automation capabilities as well.
Did you find the plugin again already? Sorry for bothering, but with this i will be in heaven with my JX-8P. :angel4:
Snarecrash
Real name: Mark
Postby snsr » Fri Jun 12, 2009 5:46 am
I've not seen a VST editor for the JX8P, but before scoring my PG-800 I picked up a BCR-2000 midi knob panel that can transmit sysex messages via midi to the jx8p. I never finished programming it, though. As iprog mentioned, the PG-800 transforms the synth, really - should be considered a required accessory. Get a midi arpeggiator or sequencer, too (ableton live!). If you're patient with ebay you can find a sane deal on a PG.
Since I've mentioned it, the PG-800 connects to the JX-8P with a 6-pin DIN cable (NOT a midi cable) that's also used as a Commodore 64/VIC 20 tape drive connector - I found mine after looking at this thread:
viewtopic.php?f=5&t=43148
snsr
Postby Snarecrash » Sat Jun 13, 2009 8:28 pm
Thank you snsr for the hint with the BCR2000, it's maybe the best solution as long as i can't get my hands on a PG-800. Btw, theres currently a PG-800 on german ebay, it's already at over 300 euros and the auction goes two more days! That's INSANE!!! :shock:
At least i already have the right cable as i have some of those C64 cables lying around.
Snarecrash
Real name: Mark
Postby Pro5 » Mon Jun 15, 2009 1:24 am
I use BCR with my JX-8p and it works great.
Currently using (rating/10): SH2(9.5), JX-3P(9), Prophet 6(9), JD-800(8.5), Crumar Performer(?)
Recently gone:Polysix(8), Prophet Rev2(6.5), Slim Phatty(7), JD-XA(7.5), Sub 37 (7), Juno 106(6.5), DX7 II-D(6), V-Synth(6.5)
Pro5
Gear: Prophet 6 | SH-2 | JX-3P | JD-800 | Performer
Postby jorr.it » Wed Oct 17, 2018 7:29 am
You could use my BCR2000 preset file and layout:
https://github.com/jorr-it/jx8p-controller
The repository contains both preset files for BCR2000 as well as Novation SL Mk II. I tried both, but prefer the BCR2000 because no menu diving is needed.
jorr.it
Return to HELP!
Users browsing this forum: No registered users and 14 guests
