pin of RCA connector broke off into the jack:
mome rath
Post by mome rath » Sat Jun 20, 2009 4:25 am
RCA connector broke off into the jack on my mackie MR5 monitor. does anyone have a neat trick to get this out or do I have to replace the jack?
the pin is jammed aaaaaaalllll the way in #-o
god elton can't you suck
Old Iron Giant
Gear: Virus Ti2, Indig2, EmuXL7, Microkorg.
Band: KHz+
Re: pin of RCA connector broke off into the jack:
Post by Old Iron Giant » Sat Jun 20, 2009 5:15 am
can you push it out, from the other side of the jack?
Last edited by Old Iron Giant on Sat Jun 20, 2009 5:21 am, edited 2 times in total.
blanik
Post by blanik » Sat Jun 20, 2009 5:15 am
a pointy metal screw about the same diametre of the RCA pin, a turn or two into the pin's center and pull gently
mome rath
Post by mome rath » Sat Jun 20, 2009 5:56 am
Old Iron Giant wrote:can you push it out, from the other side of the jack?
i opened it up to check. i don't like the way these are put together, though and I'm not sure how much grubbing around in there I want to do.
blanik wrote:a pointy metal screw about the same diametre of the RCA pin, a turn or two into the pin's center and pull gently
i'll look into this option tomorrow, thanks
space6oy
Post by space6oy » Mon Jun 22, 2009 3:58 am
probably gonna have to put a rubber tube over the jack and suck it outta there :thumbleft:
Esus
Post by Esus » Mon Jun 22, 2009 4:28 am
If possible, replace the whole jack. They're not that expensive, and chances are, you'll probably bung up one of the contacts trying to fix it anyway.
Buy 2 replacement jacks, preferably not from Radio Shack. That'll save you a possible extra trip. :)
Hope it works...
killedaway
Gear: Electribes x 6
Revolution
Monomachine MKII
microKORG
CS01
& more!
Band: killedaway/allyourblood
Post by killedaway » Fri Jun 26, 2009 3:24 am
space6oy wrote:probably gonna have to put a rubber tube over the jack and suck it outta there :thumbleft:
i put my face right up on my TV and sucked out the pin from my Wii's a/v cable, after it came loose and broke off inside. not my finest hour, but it did the job.
you ever get it out, mome?
1.5.9.13
1.5.9.13
mome rath
Post by mome rath » Fri Jun 26, 2009 4:21 am
i'm just using the TRS jacks instead
=D>
killedaway
Revolution
Monomachine MKII
microKORG
CS01
& more!
Post by killedaway » Fri Jun 26, 2009 4:22 am
mome rath wrote:i'm just using the TRS jacks instead
=D>
fair enough. quitter. :P
1.5.9.13
1.5.9.13
