Syncing TR-606 to Oberheim OB-8 arpeggiator
Re: Syncing TR-606 to Oberheim OB-8 arpeggiator
Postby bleurgh » Fri Aug 07, 2009 12:03 am
WhinyLittleRunt wrote:so we ran a CV out from the Pro One into the CV-in on the Mono/Poly which was cool but it still doesn't work to trigger the arpeggiator.
Did you actually mean "CV" or did you mean gate? Because it needs to be the gate out and it needs to be connected to the Monopoly's arpeggio trigger in. As I'm typing this, I'm listening to my Monopoly and Juno arpeggiators in perfect sync with the gate out of the Monopoly connected to the Juno's arpeggio in.
WhinyLittleRunt wrote:i will look into a Kenton Pro Solo anyway; I've wanted to for years but I keep putting it off as something I really don't need.
Well... I think you do! Or something like it. It will make things a lot less frustrating. However I just tried working out the puzzle of connecting all that gear together with the Pro-solo, but whatever way you do it, it looks like one of the three synths is going to miss out. However, this assumes that the gate out on the Pro-solo is not capable of reliably triggering sequencers/arpeggiators. I'm not sure about that as I sold my Pro-solo years ago and can't remember or try it out. It does have a clock output though, as well as a SYNC24 output.
bleurgh
Postby nathanscribe » Fri Aug 07, 2009 12:24 am
bleurgh wrote: the gate in port on the Pro-one doubles as the clock in.
OK. :oops:
nathanscribe
Postby Solderman » Fri Aug 07, 2009 3:34 am
You may also consider contacting Vaco Loco and describe your situation to see if the MIDI 2 SDS can be used to trigger your devices.
--Solderman no more.
Solderman
Postby solitud » Wed Apr 25, 2018 10:35 pm
Nearly ten years later I had the exact same problem like OP:
My TR-606 did not trigger the arpeggiator of an Oberheim OB-8.
If some other guy will have the same problem in 2028 the answer is:
you have to convert the gates of the 606 to S-Trigger.
It's pretty easy to diy:
http://www.doepfer.de/faq/gen_faq.htm#S-Trig
solitud
Gear: Ghosts and Ghouls
Previous
Return to HELP!
Users browsing this forum: No registered users and 13 guests
