heres my problem..
today i bought an AKAI AX 60 @ auction .. untested......
ok so i rush home keen as to try it out .. im in australia so it uses a different voltage to what we use here..
i used a plug converter to plug it in .. totally not thinking .. just blinded with excitement as its been a while since ive had a new toy.. anyways i am now aware those plug converters dont convert voltage.. and i think i plugged in the wrong slot anyway...
short and curly is it turned on and went zzzzzztt.... now the best part is did not smell any electrical burns or anything just the noise ... so i mopened her up and found this fuse blown...
is this all i have damaged and simply need to replace the fuse and get a step down transformer .. or may i have seriously fkt my new board upp beyond repair..
i added some photos for you to look at .. the fuse iin red is the blown one the others are fine....
anyways
thanks for any help peeps ..
there aint much info or repair info at all re this particular synth...
i hope it aint fatal or ill be kicking myself ...
peace C.C
