Moog sonic 6....
Moog sonic 6....
Postby sam » Tue Nov 03, 2009 9:16 pm
I want to recap the power supply....I see two large old caps, What can i replace them with ...?
Modern replacements ....?
Lam memorymoog.Sonic six.Vp330 mk1.SH101.OSCar.ARP odyssey..multivox mx3000.Solina stringsynth.polivox
ms20/50.Andromeda. OBX.
Prophet 5 Pro-one. Wasp.EMS AKS.
sam
Re: Moog sonic 6....
Postby sam » Wed Nov 04, 2009 4:04 pm
Anyway the main fault is this....
The keyboard always sustains, The pitch is fine but the keys always play.
I first looked at the envelope generator and replaced ic 14 but it has made no difference.
I now look at IC 4 and 5.....
Any idea's would be very appreciated .... :D
sam
Postby sam » Thu Nov 05, 2009 12:26 pm
I have replaced ic 4 (741)....But no difference.
Should i look at ic 5..?
BTW..The schems are easy to google... :D
I restore my own synths and have a good knowledge of electronics...I have not worked on a sonic 6.
So any info would be great.
sam
Postby sam » Sat Nov 07, 2009 1:14 pm
I think i have found the root of this problem.....The -ve rail is reading 22V and should be 15v.
The +ve side is ok...I think the ic 1 (741) could be at fault.
Anyone..?
sam
Postby schmidtc » Sun Nov 08, 2009 2:43 am
A bad op amp shouldn't give you a voltage rail out of whack like that. But, replacing those 723 voltage regulators is certainly a good idea. -22V sounds pretty close to the unregulated voltage coming off the rectifiers. Dropping in a new IC11 should put it right.
schmidtc
Postby sam » Sat Nov 14, 2009 8:51 pm
OK...Thank you the new chip solved that problem but it still hangs on the last played note as if the bypass switch is on.
Very strange....Any ideas...?
sam
Postby sam » Mon Nov 23, 2009 1:55 pm
I have found the main problem...Q7 TIS97 transistor in the ad circuit.
But where can i find one....Or is there a replacement...?
sam
Return to HELP!
Users browsing this forum: Bing [Bot] and 1 guest
