OK, so I got that M-12 that was on the Austin CL (but was in Dallas metro area). It belonged to seller's late father and was told by his tech that only 6 voices worked. She did not have an amp to text it, but it did power on. I ran the tuning proceedure and everything failed: VCO, PW, VCF, RES & VCA. I took it home taking a chance that it might work.
First, I got no sound from both keyboard and MIDI. Later, I discovered that the M-12 disables any voices that do not pass tunig proceedure. I manually turned on all the voices. Voices 1-6 sounded (WAY out of tune) and 7-12 are silent.
Does anyone know if there may be anything wrong besides the CEM chips? I certainly hope so because I cannot locate the CEM3374's anywhere. There's a couple of matched sets of CEM3372's on eBay. And if it is the CEM's that need replacing, does anyone know where I can find CEM3374's (neither SynthTech nor Vintage Planet has them)?
Matrix 12 & CEM3372, CEM3374
Re: Matrix 12 & CEM3372, CEM3374
dont assume anything. i've seen opamps that are just south of VCO chips go south. w/ no scope, never would have found it.
my suggestion:
1: MAKE ABSOLUTELY SURE you discharge any static in your hands. wristguard good, not critical IMO.
2: swap CEM chips from working to non-working voices. this will at least identify if its that chip or not.
another thing: on my M12, i've noticed that the machine needs to have EVERY internal harness sat snugly and properly. one thing i would also do is go thru every harness, unseat, blow out w/ compressed air, reseat SNUGLY. but if you have 6 working, 6 non-, the harnesses are unlikely as a culprit for this particular problem.
my suggestion:
I'm guessing there could be quite a few things up beside bad CEM chips, so yea, try swapping them. Hard to say, until you open it up and start poking about.
CEM3374's are usually pricey (>$100) and hard to find. The best source for them is probably a busted chroma polaris.
This feels like the DAC has failed.....
Hey schm...Thanks for the sonic help..
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
