Tb-303 issues - won't play patterns
mooghappy
Post by mooghappy » Wed Nov 18, 2009 2:27 am
I got a Tb-303 (acidlab minimodular modded) that seems to be working 100%, except after I've written a pattern for it and go press run, the pattern doesn't run. I had this issue when I first received the Tb-303 (about 6 monhts ago), and somehow managed to fix it by taking the batteries out and waiting a couple minutes and putting the batteries back in (unless it happened to be some coincidence and just started working again). It worked fine for a month or so, and then had the same issue, no pattern playback. I tried the battery trick again but not luck this time. The patterns are being stored (I can run through the notes in pitch mode), so I guess it's just a bad run/stop button? The run/stop led comes on when I press the start button. It's almost like it's in sync mode even though there's nothing synced to it (and it also doesn't run when I try to sync it).
Anyone had this issue before?
Know any good repair techs in the US for 303's?
I called Musicians Service Center in San Jose, they told me to bring it down, any idea how good these guys are?
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Re: Tb-303 issues - won't play patterns
Post by Maschinengeist » Thu Nov 19, 2009 1:29 am
My first guess is also a faulty start button. But I'll try to look at the schematics for other possible issues.
MuzikElektronix.com
Help? See TechZone
Parts? email!
Sorry, they aren't free
mooghappy
Post by mooghappy » Thu Nov 19, 2009 7:43 pm
Yeah, that's what I'd guess as well...but if it's just the start button, would that also cause it not to work from din sync?
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Post by Maschinengeist » Thu Nov 19, 2009 8:06 pm
The DIN too? Then where're obviously talking of something else. Let me check my documents.
MuzikElektronix.com
Help? See TechZone
Parts? email!
