Yamaha CS50 - Buffering problem?
Postby rivand » Thu Nov 19, 2009 7:27 pm
Hi to everyone ;)
I have a problem with my Yamaha CS-50 synth..
When I play the fourth note of a sequence, it fails and produces a sound like a pop. To be more clear I add some details:
- the problem is still present playing the same note for four times consecutively: for the first three times all is ok..but the fourth it fails;
- the problem is present also in polyphonic playing: for example holding down two keys, if I press another key it sounds good, but the note that I'll play after that will produce the unwanted pop
- the problem is present both with preset and panel mode, even if in the second case, arranging some parameters the problem can be masked a little
Since the CS-50 is a 4 poly synth, could be a problem of the buffer? And in this case which one?
Thank you in advance
rivand
Re: Yamaha CS50 - Buffering problem?
Postby pflosi » Thu Nov 19, 2009 8:17 pm
sounds like you got a problem with voice 4
pflosi
Postby rivand » Fri Nov 20, 2009 1:04 am
pflosi wrote:sounds like you got a problem with voice 4
Thank you for your answer pflosi :D
but I'm a real noob :oops: ...and maybe I can't understand what does it mean.
Was my guess right? For example could it be a problem of the 4th s/h circuit?
Or the voice 4 problem, the one you are referring to, is related to one of the several blocks along the voice4 line? :o
Thank you in advance!
rivand
Postby Cumulus » Fri Nov 20, 2009 9:58 pm
As I understand it, there are four voice cards inside the machine (1 for each voice). Your problem is probably with the fourth one. I beleive the voices all come before the filters and all that other stuff.
Mine has an intermittent problem with voice #4 as well. It does not pop but the notes are off. (Well, every 4th note is off, anyway.).
The thing about mine is that it only happens sometimes and then it goes away.
I think your best option is to take it to a tech and have them look at it.
Cumulus
Band: Cumulus
Postby Cumulus » Mon Dec 07, 2009 1:33 am
After posting to this thread I pulled out the CS-50 and fired it up.
Normally, the problem shows up after the synth has warmed up for a while (if it shows up at all). Today that's exactly what happend but I tried somethign I have never done in the nearly 20 years I have owned it. I left it on for a couple of hours. When I came back to it the problem was totally gone and the tuning is perfect from voice to voice.
I am taking it to be serviced tomorrow. I sure hope they can diagnose the problem if it doesn't show up.
Cumulus
Band: Cumulus
Postby guitarsandsynths » Tue Dec 08, 2009 6:10 am
Mine needs to warm-up before voices 3 and 4 stabilize.
Minimoog ModelD Prophet5 Roland Jupiter8 SH7 GR9 CSQ100 TR606 TR707 TR727 Oberheim OB8 ARP2600 KorgVC10 Rhodes73 Wurlitzer 200A ClavinetII DOTCOM PearlDRX1 TamaTS202 Simmons SDS9
guitarsandsynths
Real name: Angelo Metz
Band: Brazility
Postby rivand » Wed Dec 09, 2009 12:34 pm
How long does it take to warm up completely?
rivand
Postby madtheory » Wed Dec 09, 2009 7:58 pm
If you're lucky, it's a dodgy capacitor on the voice 4 board. If you're not lucky, it's one of the chips, they're CMOS and are at the end of their lifespan pretty much.
If you don't know much about electronics, servicing this instrument is not a good way to learn.
You can eliminate the "buffer" (as you call it) as an issue if you swap the boards around. Put the "faulty" board in slot 3. If the fault happens on every third note, then you know it's the voice board and not the keyboard control circuitry.
See if you can get the service manual, otherwise, take it to a tech.
Band: madtheory
Return to HELP!
Users browsing this forum: No registered users and 10 guests
