Juno-106 problem (not voice chip)
CuBulo
Real name: rees
Gear: toyota
Band: priima
Post by CuBulo » Sun Dec 27, 2009 4:56 am
I just bought a Juno-106 from a guy on VSE for $500. He said it was in great condition with all of the voice chips working which is true. All six voices are playable. But I am having one problem. When on poly 1 mode there are some notes that are bit quieter than the rest. Each quiet note is 6 notes away from each other, and the every once in a while the placement of the quiet note changes, while still being 6 notes from the next. When in poly 2 mode there are quiet notes but they are randomly grouped together and change every few seconds. There are no quiet notes when in unison mode. Please help me.
wiggle diggle do
Synthaholic
Re: Juno-106 problem (not voice chip)
Post by Synthaholic » Sun Dec 27, 2009 3:19 pm
Sounds like your Juno needs to be calibrated.
The service manual can be downloaded from here: http://manuals.fdiskc.com/flat/Roland%2 ... Manual.pdf
You'll need an oscilloscope, DVM and frequency counter or tuner to do the job properly. But as a quick fix, you could do the VCA Gain adjustment on page 19 of the service manual by ear. That should take care of the voices being unequal levels.
Turn on the Juno while holding down the KEY TRANSPOSE button. This will enter Test mode. Then press POLY 1 & 2 simultaneously so both are lit; this will cause the synth to rotate between the voices while playing and show which voice is playing on the LED. Strike a note repeatedly and note which voice is the one that is too quiet.
Then look on the module board for trimmers as follows:
Voice 1: VR27
Voice 2: VR22
Voice 3: VR17
Voice 4: VR12
Voice 5: VR7
Voice 6: VR2
Adjust the trimmer for the affected voice to bring it to the same level as the other voices.
That should get you up and running until you can either get the synth to a tech for a full calibration or acquire the gear to do it yourself.
CuBulo
Real name: rees
Gear: toyota
Band: priima
Post by CuBulo » Sun Dec 27, 2009 5:47 pm
Thank you so much :D im glad I don't have to pay for a new voice chip
wiggle diggle do
CuBulo
Real name: rees
Gear: toyota
Band: priima
Post by CuBulo » Sun Dec 27, 2009 8:46 pm
WE TRIED THE TRIMMER AND IT IS DEFINITELY VOICE 1, VR27-GAIN, BUT EVEN BROUGHT UP ALL THE WAY IT IS MUCH LOWER THAT THE OTHER 5 VOICES. I DO NOT THINK IT IS RESONANCE OR ANY OF THE OTHER SETTINGS. ANY OTHER SUGGESTIONS? COULD THE GAIN BE LOW AND THE CHIP STILL WORKS OK? I PRESUMED THAT THE CHIP EITHER WORKS OR IT IS BROKEN SO THERE IS NO SOUND AT ALL. THANKS.
edit: caps was on :-/
wiggle diggle do
Steve Jones
Real name: Steve
Post by Steve Jones » Sun Dec 27, 2009 8:48 pm
A quiet voice can be a VCA or a VCF issue... If you push up the resonance and pull down the cutoff to get a peaked filter sound, does the voice in question still sound softer, or does it have a different tone as well?
CuBulo
Real name: rees
Gear: toyota
Band: priima
Post by CuBulo » Sun Dec 27, 2009 9:01 pm
Yes it is a different tone as well.
wiggle diggle do
Synthaholic
Post by Synthaholic » Sun Dec 27, 2009 9:25 pm
You'll need to calibrate the filter on that voice then.
If the pitch of the tone is off compared to the other voices with resonance all the way up, adjust it with VR29 (voice 1).
If the resonance is weaker on that voice compared to the other voices, adjust that with VR26.
After calibrating resonance, recalibrate the VCA level on that voice.
Where are you located? If in the northeast USA, I could calibrate it for you.
CuBulo
Real name: rees
Gear: toyota
Band: priima
Post by CuBulo » Sun Dec 27, 2009 9:37 pm
Im in Louisiana
wiggle diggle do
CuBulo
Real name: rees
Gear: toyota
Band: priima
Post by CuBulo » Sun Dec 27, 2009 11:44 pm
I have done all you said and nothing has worked. Im starting to think it may just be a bad voice chip that needs replacing.
wiggle diggle do
Steve Jones
Real name: Steve
Post by Steve Jones » Sun Dec 27, 2009 11:57 pm
CuBulo wrote:I have done all you said and nothing has worked. Im starting to think it may just be a bad voice chip that needs replacing.
Sounds like a VCF/VCA chip failing.
CuBulo
Real name: rees
Gear: toyota
Band: priima
Post by CuBulo » Mon Dec 28, 2009 12:07 am
The VCF is working fine, the VCA seems also not to be the problem. And why would the VCA or VCF have a problem with only one voice?
wiggle diggle do
Steve Jones
Real name: Steve
Post by Steve Jones » Mon Dec 28, 2009 12:21 am
What you are calling a "voice chip" is a Roland module that contains the VCF and VCA for that particular voice. It is not a voice chip as such, it is not even a chip, rather it is an encapsulated sub-board with some chips and caps and some surface mount resistors on it. Roland called it an 80017A. They have always had a high failure rate, and they have several failure modes, including the one that you have described. There is one for each voice, so a failing module will only effect that particular voice.
CuBulo
Real name: rees
Gear: toyota
Band: priima
Post by CuBulo » Mon Dec 28, 2009 1:10 am
So replacing the voice chip would fix the problem correct?
wiggle diggle do
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Post by Maschinengeist » Mon Dec 28, 2009 1:34 am
I should check in my boxes but I think I've got a 80017a left.
MuzikElektronix.com
Help? See TechZone
Parts? email!
Sorry, they aren't free
CuBulo
Real name: rees
Gear: toyota
Band: priima
Post by CuBulo » Mon Dec 28, 2009 2:40 am
Where can I buy a replacement?
wiggle diggle do
