Jomox Xbase 09 NOISY Mix Out?!?!
analoglsd
Real name: Lance
Gear: Buchla Music Easel, TE OP-1, Korg MS-20, Yamaha RS-7000, Effects Pedals
Post by analoglsd » Mon Feb 08, 2010 9:28 pm
Hi,
My Jomox Xbase 09 OS 2.09, has a very noisy Mix Out.
All the individual outputs are as quiet as can be.
The noise I hear reminds me of the noise heard in the Electrix Repeater, where you're hearing some sort of electrical cross talk.
For example: when I scroll through the numbered patterns, I can hear it.
There's a louder "buzz" on some patterns than others.
Also, when the volume knob is all the way down, the "buzz" is the loudest.
When the volume knob gets to 12 o'clock the buzz goes away and is replaced by a "hum" which increases as you turn it up.
Help.
Please.
Thanks.
Kraig0078
Re: Jomox Xbase 09 NOISEY Mix Out?!?!
Post by Kraig0078 » Mon Feb 08, 2010 9:36 pm
my old X base was like that and I always suspected the power supply as the culprit.
Synths:Prophet 08,Prodigy,Mono/Poly,Juno 106
DX 21,Micro Q
Drums:X Base 09,MPC 1000,Battery 3
analoglsd
Real name: Lance
Re: Jomox Xbase 09 NOISY Mix Out?!?!
Post by analoglsd » Mon Feb 08, 2010 9:49 pm
I'm using the original Jomox PS, were you?
Kraig0078
Post by Kraig0078 » Thu Feb 11, 2010 4:57 am
Yes, I was also using the original power supply. Im just thinking maybe the power supplies were not of the best quality and a replacement might fix the problem. I ended up selling mine "as is" so im not sure what the outcome would be.
DX 21,Micro Q
