Help needed to replace Juno 106 battery
guitarsandsynths
Real name: Angelo Metz
Band: Brazility
Post by guitarsandsynths » Fri Feb 12, 2010 10:51 pm
I have the Juno open, I'm looking at the battery, but cant get it out. :? Is there a trick here? Is it soldered under the little metal contact tab? Do I have to remove the board? Can some one please guide me thru this? Thanks in advance!
Angelo
Minimoog ModelD Prophet5 Roland Jupiter8 SH7 GR9 CSQ100 TR606 TR707 TR727 Oberheim OB8 ARP2600 KorgVC10 Rhodes73 Wurlitzer 200A ClavinetII DOTCOM PearlDRX1 TamaTS202 Simmons SDS9
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: Help needed to replace Juno 106 battery
Post by rhino » Fri Feb 12, 2010 11:24 pm
if its a flat, round 'coin cell', you'll be better off removing the board so you can get at the solder under it. Watch the heat ...the battery can explode.
- Confucius
Bross
Post by Bross » Fri Feb 12, 2010 11:45 pm
It's a good practice to snip the battery leads to remove the battery and then desolder them from the board to avoid heating up the old battery.
Synthaholic
Post by Synthaholic » Sat Feb 13, 2010 12:22 am
And another tip: instead of buying a replacement solder-in battery, get a battery holder and a regular CR2032 coin battery. If you're in the USA, RadioShack carries them. Solder the holder onto the board, then insert the battery. Future replacements will be as easy as popping the old battery out and popping the new one in! :)
guitarsandsynths
Band: Brazility
Post by guitarsandsynths » Sat Feb 13, 2010 2:42 am
Thanks a lot guys!
I'll get the battery holder. I'll post the results. Thanks again! =D>
guitarsandsynths
Band: Brazility
Post by guitarsandsynths » Sat Feb 20, 2010 1:41 am
I installed a battery holder and a fresh battery. The Juno now has the same patch in every location. Doesn't write or load. Any ideas?
Synthaholic
Post by Synthaholic » Sat Feb 20, 2010 5:39 am
Is the protect switch on the rear set correctly?
Also, did you install the battery holder and battery with the correct polarity?
guitarsandsynths
Band: Brazility
Post by guitarsandsynths » Sat Feb 20, 2010 8:23 am
The switch was properly set. I followed the procedures in the user's manual. I'm pretty sure the polarity is correct too. Should I try to flip the battery?
Thanks a lot!
Angelo
Real name: Unpronounceable
Band: Eridani V
Post by Ashe37 » Sun Apr 18, 2010 10:41 am
EET EES MINE!!!!
(I Have this Juno now and am still working on this patch storage problem)
guitarsandsynths
Band: Brazility
Post by guitarsandsynths » Sun Apr 18, 2010 6:52 pm
Good luck!
Let me know how it turns out! ;)
