Just picked up a Freeman String Symphonizer (made by CMI under the Cordovox name).
Anybody here have one? Need some info:
1. A picture or sketch of how the metal legs mount to the bottom of the case. Is there an 'angle' adjustment?
2. What did the music rack look like? What material?
3. Any clues as to some amp, mixing desk, etc. that might have similar wide rubber "T" edge-moulding?
thanks
freeman stringer info
- rhino
- Real name: bill
- Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
- Confucius
- Confucius
- rhino
- Real name: bill
- Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Re: freeman stringer info
none of you young(er) guys have played one?
found a picture of the music rack (smoke plexiglas)
found a source for the plastic case trim edging
still need to know what the upper part of the legs look like (they fasten to the case with one large bolt)
is there an angle adjustment?
what (if anything) was printed on the audience-side of the leg cross-bar?? CMI, FREEMAN, CORDOVOX????
- Confucius
- Confucius
i own one. however, i unfortunately generally dont care about those kinds of things, so can't help ya buddy....sorry....
dont have the legs,stand, whatever...
- WhinyLittleRunt
We just got one last week for the studio, coincidentally. Not sure about legs or anything; this one had the two wooden rails underneath it that act like feet, but I removed them so it would fit comfortably on a regular kb stand... It came with an expression pedal which so far seems like a pitch bend, but it's also got some issues so who knows if it's working correctly... Overall it's pretty cool; I think the sound was more similar to Roland's string ensembles than ARPs.
I like vintage synths....
- rhino
- Real name: bill
- Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
if that's the original pedal, the little tab on the left is a 'glide' switch: pressing it with your shoe will drop the pitch 1/2 step. Supposed to simulate portamento and 'fiddle' -playin' style attacks.
- Confucius
- Confucius
