Roland JP-8000 reboot
- Alex E
- Gear: Jupiter-6, Juno-60, Polysix, Emulator II, DX7, QX1, Arp Odyssey MKII, ESQ-1, Miami, M1r, Live 9, iMac MC309XX/A
I replaced the battery in mine this afternoon, and LFO 2 and the ribbon controller aren't working as they should. I heard when replacing the battery you may need to do a key combination on startup. Can someone please enlighten me on this subject?
I've already done a factory reset several times.
soundcloud.com/vectron
Re: Roland JP-8000 reboot
http://www.rolandus.com/products/produc ... ductId=261
Rom Update...
Reset Pitch Bender and Ribbon Controller Procedure:
1) Turn on power while holding [OSC2 SYNC], [-12dB/-24dB] and [FILTER TYPE] to enter Test Mode. Wait until display
indicates "[1] MIDI Test."
2) Press the [3] button to display "[3] Bend Mod."
3) Push the bender lever left fully and gradually return it to the center. Press [LOWER].
4) Push the bender lever right fully and gradually return it to the center. Press [UPPER].
5) Push the bender lever to the MOD position and then gradually return it to the original position. Press [KEY MODE].
6) When the '*' appears on the display, press [UP].
7) From the previous display, press [4] to display "[4] Ribbon."
8) While pressing down on the left edge of the ribbon controller, press [LOWER].
9) While pressing down on the right edge of the ribbon controller, press [UPPER].
10) While pressing down on the center of the ribbon controller, press [KEY MODE].
11) When the '*' appears on the display, press [UP].
12) Turn off the power of the JP-8000.
Use the following procedure to reset the JP-8000 to factory settings:
1) Turn on the power of the JP-8000. The unit may display "Memory Damaged."
2) While holding [SHIFT], press [INIT/UTIL].
3) Press [INIT/UTIL] repeatedly to select "INITIALIZE WRITE."
4) Use the [UP / DOWN] buttons to select "FACTORY PRESET," then press [WRITE]
Rom Update...
Roland V-Synth GT,Juno-2,D-50,JD-800,JP-8000,JX-8P,JX-305,VS-1680(2 x VS8F-2).Clavia Nord Lead 2,Nord Lead 3. Alesis ION.Korg Radias (kb),Z1,Trinity plus,Karma,DW-8000.Novation Supernova II pro (kb).Waldorf MicroWave XT.Yamaha DX7 II FD, DX21.Ensoniq SQ1+
