Another dead instrument
Cumulus
Band: Cumulus
Post by Cumulus » Wed Apr 28, 2010 11:07 pm
I was putting frash bateries in several pieces of gear in preparation for tomorrow night's show and Lo, and Behold, the TR-606 is completely dead!
New fresh C cells failed to revive it. The old ones didn't leak or anythign and they haven't been in there very long but it's completely dead.
Just in time for me to pick up the 808 and the CS-50 at the repair shop... :(
Cumulus
Band: Cumulus
Re: Another dead instrument
Post by Cumulus » Wed Apr 28, 2010 11:17 pm
Looks like the shop moved to Palm Harbor, FL. A little further to drive....
alspacka
Post by alspacka » Wed Apr 28, 2010 11:29 pm
I had a 606 die on me as well.
altho I did drop it on the floor.
LesDeuxLoveOrchestra
Post by LesDeuxLoveOrchestra » Wed Apr 28, 2010 11:41 pm
be sure to check it with a power supply before saying rip.
Cumulus
Band: Cumulus
Post by Cumulus » Wed Apr 28, 2010 11:43 pm
I am looking at power supplies right now. Chip For Brains has one that looks like it will do the job.
n1nj4
Post by n1nj4 » Fri Apr 30, 2010 7:45 am
Also check for broken or loose solder connections on the battery contact wires.
sequentialsoftshock
Real name: Zayne
Band: Echo & Liora
Post by sequentialsoftshock » Fri Apr 30, 2010 7:49 am
Cumulus wrote:I am looking at power supplies right now. Chip For Brains has one that looks like it will do the job.
I've been using a new boss PSA power supply that works fine with my 606; you may want to check that option before waiting a while for delivery =/
bonne chance
Computer Controlled
Gear: SH-101 . TB-3 . TR-8 . Juno-1 w/PG-300 . TT-303 . Korg ES2 . Beatstep Pro . Pioneer RMX-500
Band: Computer Controlled
Post by Computer Controlled » Sat May 01, 2010 9:12 am
You can use any standard wall wart adapter that delivers 9v and 300Ma or more. Go to Rat Shack or Wal-Mart and grab one. Just make sure you put the tip on so you have a negative center.
Synths:
Avalon Bassline . TB-03 . JU-06 . MX-1 . Blofeld . MicroMonsta . Akai S5000
Drum Machines:
TR-09 . TR-8
Cumulus
Band: Cumulus
Post by Cumulus » Wed May 12, 2010 1:25 am
My power supply arrived this afternoon from Hong Kong so I plugged it in not really thinking anythign good would happen but, amazingly, the things works perfectly!
I hate the fact that it does not work on battery power but at least it's working.
Cumulus
Band: Cumulus
Post by Cumulus » Thu May 13, 2010 1:29 pm
So what would cause the 606 to work with the AC adapter but not with battery powere. There doesn't seem to be any battery leaskage issues inside the battery compartment.
Is ther esomethign specific I shoudl check if I want to fix it myself?
Altitude
Post by Altitude » Thu May 13, 2010 4:04 pm
Broken wire on the battery terminals
th0mas
Band: GRAVITRONIC
Post by th0mas » Thu May 13, 2010 5:14 pm
Altitude wrote:Broken wire on the battery terminals
+1 given age, etc.
With a multimeter check if voltage is reaching the board from the batteries, if not, trace the wires back, check at the switch, make sure all the metal terminals (including the one that's usually across from the terminal with wires on it) are seated properly, resolder anything that's busted.
minime123
Post by minime123 » Thu May 13, 2010 5:20 pm
some battery terminals are longer than others. make sure the batteries are actually making contact. if not, you may have to remove and bend the metal contact point.
mini
VINTAGE SYNTH DEALER
- https://tonetweakers.com
Cumulus
Band: Cumulus
Post by Cumulus » Fri May 21, 2010 3:06 am
The batteries seem to be making contact. I will have to do some more testing.
On a positive note I picked up the 808 and the CS-50 from the repair shop today. I haven't played them yet and I can't wait.
iProg
Real name: Carl
Band: ArtWithHeart
Post by iProg » Fri May 21, 2010 3:56 pm
Nothing lasts forever. Analog electronics are no exception.
