Light Cleaning of a 606
Ned Bouhalassa
Gear: A new German poly monster, an old BBC Brit, a vintage poly beast from NY, someone's older relative from NC, and Eurolicious patchables.
Post by Ned Bouhalassa » Tue Jun 01, 2010 4:41 pm
I want to clean the the outside of a TR-606 I was given. It's in great shape, but there's some dust that has become dirt over the years. I'm thinking that all it need to use is a little soap in water that I would dab around the pots and such using a q-tip. Any other suggestions?
My music: soundcloud
My analog synth videos nedonanalog
More about me: Mostly Human Music
schmidtc
Re: Light Cleaning of a 606
Post by schmidtc » Tue Jun 01, 2010 8:15 pm
For this kind of thing you might try isopropyl alcohol pads. 99% iso is best, but the 70% pads leave hardly any water behind and are available at any pharmacy for cheap. I've used these for cleaning my 606 case with good results.
Ned Bouhalassa
Post by Ned Bouhalassa » Tue Jun 01, 2010 8:30 pm
Good tip - thanks, man! And FWIW, I'm a BIG time Bruins fan. ;-)
Altitude
Post by Altitude » Sat Jun 05, 2010 12:12 pm
schmidtc wrote:For this kind of thing you might try isopropyl alcohol pads. 99% iso is best, but the 70% pads leave hardly any water behind and are available at any pharmacy for cheap. I've used these for cleaning my 606 case with good results.
um, no.
Alcohol will eat away the paint and/or silk screening. Made that mistake with my 606
Might have worked with the pads you found but you should never use solvents for cleaning.
Whatever you use, test it on the underside and make sure it wont attack the paint. Personally, I use simple green for cleaning. It is as mild as it gets chemically but works wonders on grease and grime
skweeegor
Post by skweeegor » Sat Jun 05, 2010 5:05 pm
um, no.
Seconded. I tried using isopropyl on my MPK49 and it took some paint off - not enough to notice luckily but I imagine it would do the same on any other plastics.
schmidtc
Post by schmidtc » Sat Jun 05, 2010 11:51 pm
Huh.
I noticed iso took off a very tiny amount of paint on a Juno 60 I cleaned up. Otherwise I've had good results universally. Maybe it's that they don't stay wet for very long, just a wipe. I prefer iso because it's safe on electronics and doesn't leave residue. I've actually tested a few cleaning methods in a clean room with a mass spectrometer. Simple green followed by water, followed by Iso had the best results.
I use diluted simple green when bathing synths for boards and all and I've also had good results. If it gets on the boards make sure to rinse with distilled water and let them dry under a fan overnight.
