Best MIDI option for Moog The Source
phoenix224
Post by phoenix224 » Fri Jun 11, 2010 12:29 am
Hello,
I understand that the Source is fairly easily MIDI adaptable, but I could use some help figuring out the best option to go with.
I'm thinking I will likely go with the Kenton Pro Solo mk II, since it doesn't involve modifying the internal components of the Source (I'm not the type to get involved with soldering, and this synth was just recently restored by Ears Audio, so I'm not going to mess with it).
The question is how does the Kenton MIDI to CV converter rate for use with the Source? I'm using Ableton Live 8 as the host. Is it possible to get this from a US dealer, or do I have to deal with Kenton directly?
Thanks.
Overgear
Gear: AX-73, S3000, MFC42, K5000R, K4r, K1, Nord 3R, MKS-50, Juno-106, JP-8000, CS-10, CS-15, TVS-1, PP SEM(x2), Rogue, Source, Pro-One, P-600, Mopho
Re: Best MIDI option for Moog The Source
Post by Overgear » Fri Jun 11, 2010 12:35 am
Worked fine for me on the Pro2k. Check w/ audioMIDI. I wouldn't recommend mods. That's just me, though.
