Help! - Doepfer MS-404 playing always the same pitch
Antonino
Post by Antonino » Sun Jun 20, 2010 9:06 pm
Hi guys, I just bought a second hand MS-404, but I have a problem.
I tried it with several MIDI controllers, but I always seem to have a big issue: basically the notes don't change pitch :( In other words, if I play different keys on the keyboard I always seem to get a G, even if I can actually hear some slight differences in the harmonics. All the rest (LFOs, filter, etc.) is working fine.
The guy who sold me the module is honest and I do believe him when he said it was functional. He told me that he was using it fine with Pro Tools MIDI.
What can have happened? could it be a MIDI problem? is there any chance that I can solve this problem in any way without sending it to repair? thanks! :)
Hardware:Alpha Juno 2/microKORG/MS-404/Performer/S-330/Dr-550 mkII/DRP-2/PC-200/LPK25/MC-50/Console RMX/FA-101/M4400/SR1259IT---Software:Reaper/Ableton Live/Too many free VSTs---Owned:D-20/nanoKEY---Coming Soon:D110/FM7---Dreams:Fizmo
th0mas
Band: GRAVITRONIC
Re: Help! - Doepfer MS-404 playing always the same pitch
Post by th0mas » Sun Jun 20, 2010 9:28 pm
The MS-404 has CV out. Plug in a cable to the CV output and see if the voltage changes in response to different MIDI notes. If it's not changing then my guess would be it's the internal MIDI->CV converter that's pooched (if you know for certain your MIDI interface is working, say, by making sure the same method works with your microkorg).
It could also maybe be that the connection from the MIDI-CV converter to the VCO is damaged, so only gate is reaching the synth? I don't know if that would result in the VCO playing anything audible though (my guess would be it'd be attempting to play at 0V -> close to 0 Hz.
Antonino
Post by Antonino » Sun Jun 20, 2010 10:05 pm
th0mas wrote:The MS-404 has CV out. Plug in a cable to the CV output and see if the voltage changes in response to different MIDI notes. If it's not changing then my guess would be it's the internal MIDI->CV converter that's pooched (if you know for certain your MIDI interface is working, say, by making sure the same method works with your microkorg).
Thanks for the answer! I'll try this out for sure.. but how can I know if the voltage changes? It's my first true analog synth so I'm not really very handy with CV :D
Antonino
Post by Antonino » Sun Jun 20, 2010 10:52 pm
Some quick recordings of the problem (lowest note at the beginning and then a 5 octave chromatic scale):
SAW
SQUARE
NOISE
NO INPUT
RD9
Post by RD9 » Sun Jun 20, 2010 11:40 pm
Weird. It sounds like there's at least some change in pitch in the square example though.
Does frequency modulation work at least? What happens if you hold down a key (ASDR:0-0-12-0) while the frequency oscillates very slowly let's say at level-10 and freq-10 (switch up). Does the unit at least respond in the expected way?
th0mas
Band: GRAVITRONIC
Post by th0mas » Mon Jun 21, 2010 12:16 am
Sorry, I didn't explain too well.. plug a cable into the "CV out", then with a voltmeter, go to the other end of the cable and hold the leads to each side of the cable's connector (one on the tip, one on the ring) and then measure the voltage.. It should go up as you play higher notes.
Antonino
Post by Antonino » Mon Jun 21, 2010 12:21 am
RD9 wrote:Weird. It sounds like there's at least some change in pitch in the square example though.
It somehow works but in a weird way and the result is different from note to note.. This is the result:
C1 (lowest key)
C2
C3
C4
C5
C6 (highest key)
Antonino
Post by Antonino » Mon Jun 21, 2010 12:24 am
OK I get it now.. I'll definitively try that! ;)
RD9
Post by RD9 » Mon Jun 21, 2010 1:01 am
C1 (lowest key)
C2
C3
C4
C5
C6 (highest key)
Hm... That doesn't sound right. Maybe the problem is beyond MIDI/note control. I don't know anything about electronics, but maybe it's a short?
Here's a pic of my settings and an audio sample if you care to compare:
http://soundcloud.com/9dr9dr/ms-404-fm
Antonino
Post by Antonino » Mon Jun 21, 2010 1:57 am
Midi-CV works perfectly, so the problem must be something that has to do with the analog circuit, it isn't MIDI related for sure. Unless some miracle happens I think I'll have to send it to repair somewhere to make it work :(
RD9 wrote: ...
Very useful as a comparison, thanks again.
Antonino
Post by Antonino » Mon Jun 21, 2010 5:26 pm
F*CKING YESSSSS :D
I was desperate: or send it to pricey assistance or sell it low price as broken unit. So I opened the box and used the "touch and try" method.. I said " why not give it a go at this point"?
I touched random parts here and there and then the "magic condenser" near to the Audio Out.. et voila' the doepfer started to sing again!!!! Hope it lasts for a bit now, but in any case I know who the bastard is at least :twisted:
Thanks again to Th0mas and RD9.. I would really offer you a beer in this moment.. your help was essential to focus better the problem :)
Now at last I can play some notes other than G.. I was getting sick listening to those weird noises..! :D
cheers
Antonio John
th0mas
Band: GRAVITRONIC
Post by th0mas » Mon Jun 21, 2010 5:50 pm
Antonino wrote:F*CKING YESSSSS :D
cheers
Antonio John
:drinks: glad its working! Not 100% on your method but... hey, it works now right on :D
RD9
Post by RD9 » Mon Jun 21, 2010 6:05 pm
Wow that's awesome. Congrats. There are lots of great bars where I am in Brooklyn if you ever come to nyc. :)
What the heck is a magic condenser? Is that anything like a Magic Hat? ;)
moremagic
Real name: A.M.
Gear: electribe er-1, sp-303, sp-404sx, s612, nuo 2, sl-1200 mk ii, beatstep, eurorack, tb-03, vx-99
Post by moremagic » Wed Nov 03, 2010 3:44 am
Antonino wrote:I touched random parts here and there and then the "magic condenser" near to the Audio Out.. et voila' the doepfer started to sing again!!!!...
I'm wondering if I should start touching random parts of the singer to see if she'll sing in a key other than G! :mrgreen:
Rhoda
Post by Rhoda » Tue Jun 09, 2020 4:54 pm
Here's someone with the same problem.
Would anybody know what's the "magic condenser"? Thank you in advance.
