korg dw8000 midi out problem
- Gear: Alesis S4+, Yamaha: TG77, TG500, SY35, TX7, KORG: 03R/W, P3, DW6000, Kawai: K1, K4r, Roland: D-50, Fantom XR, A-33 , Oberheim: MC1000, MC2000 EX
i just got one and it seemed to work ok but when i tried to use it as a mother keyboard i realised that it can't send midi data!can anyone help?i tried to change the midi parameters but it didn;t solve the problem..by the way the midi in seems to work as the synth received midi sequences from the ableton live
- rhino
- Real name: bill
- Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo - Location: kentucky hills
Re: korg dw8000 midi out problem
If all MIDI parameters are set right and still no MIDI out, then check IC39 a 7405 hex inverter that buffers the MIDI out signal from the CPU.
- Confucius
- Confucius
