removing anodization
space6oy
Post by space6oy » Fri Dec 03, 2010 9:37 pm
anyone ever done this? i want to make my ESX-1 look like this guy's:
am digging around but am seeing a lot of different suggestions and negative responses to a lot of them...
pricklyrobot
Re: removing anodization
Post by pricklyrobot » Fri Dec 03, 2010 11:09 pm
Can't vouch for it personally, but I found a page where a guy described de-anodizing some bike frame parts with good results using this stuff: http://jestcoproducts.com/index.php?act ... oductId=37
tallowwaters
Gear: LC-MS/MS
Post by tallowwaters » Sat Dec 04, 2010 12:43 am
We used EZ Off Oven Cleaner (though any strong base should work) in one of my advanced metal working classes. Spray it on, let it sit for a few hours, repeat if needed. Be careful not to pit the Al though. Try it on a few cheapo anodized keychains first.
The real trick is polishing afterwards. Maybe hit it with steel wool and something like Brasso
tallowwaters
Gear: LC-MS/MS
Post by tallowwaters » Sat Dec 04, 2010 12:50 am
space6oy
Post by space6oy » Sat Dec 04, 2010 1:20 am
tallowwaters wrote:We used EZ Off Oven Cleaner (though any strong base should work) in one of my advanced metal working classes. Spray it on, let it sit for a few hours, repeat if needed. Be careful not to pit the Al though. Try it on a few cheapo anodized keychains first.
nice, i actually just picked up a can of that.
steel wool or would scratch off the painted lettering though, wouldn't it?
tallowwaters wrote:Here you go:
http://www.secondchancegarage.com/public/665.cfm
the drano suggestion is the one i've seen scolded the most though...
regardless, thanks for the help guys.
space6oy
Post by space6oy » Sat Dec 04, 2010 3:07 am
EZ off totally does work, just tried it on a carabiner. know if it'll eat off the lettering paint too though?
pricklyrobot
Post by pricklyrobot » Sat Dec 04, 2010 4:06 am
space6oy wrote:know if it'll eat off the lettering paint too though?
Hard to say without knowing what it actually is (enamel paint, screen-printed UV ink?). I believe spray oven cleaner is essentially lye-based, if that helps any.
space6oy
Post by space6oy » Sat Dec 04, 2010 4:19 am
pretty sure it's silk screened...
& correct on the lye/sodium hydroxide.
tallowwaters
Gear: LC-MS/MS
Post by tallowwaters » Mon Dec 06, 2010 2:45 am
I thought Drano was just NaOH/lye/caustic soda. Have to go look.
If all else fails, you can order a skin from StyleFlip. :?
tallowwaters
Gear: LC-MS/MS
Post by tallowwaters » Mon Dec 06, 2010 2:51 am
Oh, and maybe a finer grit steel wool than your typical kitchen variety, maybe 800-1000 grit (it's in powder form). The letters are etched in, correct? (I have a styleflip on, so I've totally forgotten)
Altitude
Post by Altitude » Mon Dec 06, 2010 3:18 am
You could also look at some finishing grade scotch bright (the machine shop variety), it comes in wipes and works great on aluminum. There is also brass wool which may be better on some grades of alumium
cartesia
Gear: Octatrack
Bass Station 2
Band: TBA
Post by cartesia » Mon Dec 06, 2010 4:45 am
The guy that did that posted his process over here somewhere:
livepa.org
space6oy
Post by space6oy » Mon Dec 06, 2010 9:43 pm
badass, thanks a ton!
http://www.livepa.org/board/viewtopic.php?t=5504
edit: man i have to say though, this scenario does scare the s**t outta me. wish i could find the exact same cleaner he used...
filtersweeperVCO
Gear: Voyager, MF-102, VX-351, Waldorf Pulse +, Micro Q, JX-3P, Juno 106, MPC 1000, KP3, Sherman filterbank 2, and stuff.
Band: Filtersweeper
Post by filtersweeperVCO » Wed Dec 08, 2010 4:22 am
sand blaster. I cleaned my 1200's technics like this. It removes lettering too though. But then you can brush it with scotch brite pad to give effect.
Then I powder coated them.
Synths: Moog voyager, Roland JX-3P, Roland Juno 106
Other: Akai MPC 1000, Korg Koass pd. 3, Sherman filterbank 2, Hammond T-211,Yorkville LS 800 (for bass)
pricklyrobot
Post by pricklyrobot » Wed Dec 08, 2010 5:00 am
filtersweeperVCO wrote:sand blaster.
Yeah, because people are way more likely to have one of those (and the space to use it in) sittin' around, than they are a can of oven cleaner. ;)
