Vibrating Pro One
Sorcerio
Vibrating Pro One
Post by Sorcerio » Fri Dec 10, 2010 9:19 pm
I have a Sequential Circuits Pro One. When it's powered on I feel a very light constant vibration. Is this normal?
I know it sounds funny, but it's true.
ninja6485
Band: Subliminal Sea
Re: Vibrating Pro One
Post by ninja6485 » Fri Dec 10, 2010 9:43 pm
of coarse - everyone vibrates when they play an awesome monosynth. it's one of the seldom discussed medical mysteries of the modern age. 8-)
Solderman
Post by Solderman » Fri Dec 10, 2010 10:02 pm
All jokes of the bass capability of the Pro~One aside, where exactly on the synth are you feeling the vibration? They do not get hot enough to need a fan or heat sink, even for some kind of modification, so I don't know why this would occur.
--Solderman no more.
prinsen
Gear: Blokey, MS10, Matrix-6, Kult, TR-808, Tokai Jazzbass, DIY modular + fx, amps and mics.
Post by prinsen » Fri Dec 10, 2010 10:30 pm
Sounds like a grounding issue. Are you using the proper mains plug?
Sorcerio
Post by Sorcerio » Sat Dec 11, 2010 1:18 am
It is plugged in to the same as the rest of all my other (non-vibrating) gear. The ground pin on the power cord is fully intact.
It's just an all over vibration. I haven't felt for a source, but I will when I get back to it. There are no modifications as far as I can tell. I think she is stock.
Alex E
Gear: Jupiter-6, Juno-60, Polysix, Emulator II, DX7, QX1, Arp Odyssey MKII, ESQ-1, Miami, M1r, Live 9, iMac MC309XX/A
Post by Alex E » Sat Dec 11, 2010 1:24 am
Vibrating Pro-One... That's hot. :happy3:
soundcloud.com/vectron
cave
Gear: Kawai K3, Sequential Circuits Pro One, Roland SH-101, Roland Juno 106, Roland Juno 60, Korg Polysix, Kawai K5000, Roland JV-880, Oxford OSCar
Post by cave » Sat Dec 11, 2010 3:26 am
What's your serial number?
Sounds like the transformer.
I've never had one inside a machine do that, but I used to have a number of line warts around that era that would both get hot and vibrate to the point where you could hear them.
Sorcerio wrote:I have a Sequential Circuits Pro One. When it's powered on I feel a very light constant vibration. Is this normal?
Elandroth
Gear: Nord Lead 2X, DSI MEK PE, Roland D-50/Juno-60/TR-707, Ensoniq ESQ-1, Casio CZ-5000, Elektron MD UW+
Post by Elandroth » Sat Dec 11, 2010 3:32 am
Sounds like you got one of the rare ones with the extra hidden LFO.
space6oy
Post by space6oy » Sat Dec 11, 2010 4:22 am
belongs in the help section.
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Sat Dec 11, 2010 5:21 am
Check:
1. bad power xformer (maybe only loose on the chassis)
2. Shorted rectifier diode
3. Leaky filter cap or other abnormal loading of PS.
4. Giant angry bug trapped inside.
- Confucius
tekkentool
Real name: Steve
Band: none currently
Post by tekkentool » Sat Dec 11, 2010 5:23 am
rhino wrote:Check:
:lol: That would be the first thing i'd check. ;)
garranimal
Post by garranimal » Sat Dec 11, 2010 6:44 am
Sometimes a little bit of transformer buzz is normal. Definitely check into Rhino's recommendations and make sure something is not amiss. Does anyone else w/ a pro one have a similar experience?
Computer Controlled
Gear: SH-101 . TB-3 . TR-8 . Juno-1 w/PG-300 . TT-303 . Korg ES2 . Beatstep Pro . Pioneer RMX-500
Band: Computer Controlled
Post by Computer Controlled » Sat Dec 11, 2010 9:00 am
Yeah, sounds like a transformer thing.
Synths:
Avalon Bassline . TB-03 . JU-06 . MX-1 . Blofeld . MicroMonsta . Akai S5000
Drum Machines:
TR-09 . TR-8
Altitude
Post by Altitude » Sat Dec 11, 2010 12:49 pm
+1 for the transformer. When those age, you get an increase in magnetic flux leakage which will actually cause the metal chassis to vibrate. The way i fixed it in my Tx81z was to clip a thin piece of cold rolled steel over the coil of the trafo
Post by madtheory » Sat Dec 11, 2010 1:35 pm
I've fixed a few vibrating transformers by squeezing the metal casing with a bench vice.
