Is there any reason why my Kenton Pro 2000 mkii aux channels are not putting signals out to my cv/gate synth? It used to work with no problem. All the ports 1-6 seem unresponsive.
I'm trying to control a Sequential Pro One on midi channel 5.
Aux 1 - Receive channel = 5
------V/Oct from notes
------Fine tune = 0
------Scale = 0
------Reset level = 0
Aux 2 - Receive channel = 5
------Gate from notes
------Output Level Cntl min = 0
------Output Level Cntl max = +63
First thing off, the cables are good and do work on the Kenton port A CV/Gate outputs. Cables are properly connected. Kenton Aux 1 to Pro One CV in, Kenton Aux 2 to Pro One Gate in.
The middle mode switch on the Pro One is switched to "Repeat/Ext".
Midi channels are set correctly and the midi led on the Kenton comes on when a midi note is played.
Have tried this on all the Kenton Aux ports, paired as 1&2, 3&4, 5&6.CV odd, Gate even.
What have I set wrong? What am I overlooking?
No CV/Gate from Kenton Pro 2000mkii Aux ports
- snod_donkey
- Junior Member
- Gear: Moog Minimoog - SCI Pro-One - Roland Sh-101 - Yamaha XS6 - Oberheim OB-Xa - Roland TD8 - Evans super Echo Tape Loop - Memeory Man Deluxe
Re: No CV/Gate from Kenton Pro 2000mkii Aux ports
It could be your not putting the correct gate signal to the pro one. What is the gate output? High or low as i think the pro one has to see a 5 volt high on the gate
When you say it was working... was it working ok on this unit on the aux outputs and not just the a/b outputs?
Only thing I see different in the manual is Max range for gate is +25 for 5 volts, not +63. Perhaps check the voltages with a multimeter on each jack.
--Solderman no more.
Checking with a multimeter sounds like a good idea. I'm not sure if these aux outputs are sending anything...
- snod_donkey
- Junior Member
Just tried these settings as you did
------Fine tune = 0
------Scale = 0
It is working fine for me so i can only assume you have a fault somewhere. Do a factory reset on the Kenton and try again.. other than that
------Fine tune = 0
------Scale = 0
- Phollop Willing PA
- Senior Member
- Gear: Korg, Moog, Roland, Alesis, ARP, Yamaha, Future Retro
I've had a similar problem with a Moog Multi-Pedal MP 201. I can't get the MIDI to CV program/patch to get my analogue to work.
I've ordered a Kenton Pro and selling the MP 201 (unless it can prove its worth).
Check the fuses. I had mine blow and there was no clock out or anything, then I put a new fuse in and it worked. Happened after I tried a splitter cable....
