no sound from my Alesis QS7
fazegirl1
Real name: Annie
Gear: Alesis QS7, Petrof 6'4" Medium Grand, Guild F47, Taylor CE614
Band: Fleetwood MAX!
Post by fazegirl1 » Fri Dec 24, 2010 8:42 pm
Happy Christmas Eve all! I am new to the board but found this site while trying to figure out what is wrong with My Alesis QS7. At band practice a few nights ago, I plugged it in and only got a blank but lighted screen. I found out how to reset the keys online and folllowed the directions and now have the settings and sounds displayed but no sound. The amp is working so I know it's not that. Any suggestions? I have gigs - ahhhhhh! Annie
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: no sound from my Alesis QS7
Post by rhino » Fri Dec 24, 2010 9:27 pm
Welcome to our crazy little world ! And, Merry Christmas too.
Never had a QS7, but have had several Alesis Q-series boards.
Here's what help(?) I can give:
1. Try the AUX outputs
2. Can you still use the Presets?
3. If you use a volume pedal, was it plugged in when you did the reset? If so, UN-plug it and do another reset.
- Confucius
fazegirl1
Real name: Annie
Post by fazegirl1 » Sat Dec 25, 2010 6:34 am
I just tried plugging into the aux instead of mains...still nothing...I did not have the sustain or volumn peddle plugged in when I reset the keys...
Maybe I'll have to take it in somewhere - darn!
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Sat Dec 25, 2010 6:54 am
Sadly, sounds like time for a tech. One last try: You do understand that resetting the synth has erased all the USER programs? Do the PRESET sounds work? Could be something as simple as a corroded connector inside somewhere.
Good luck. Let us know.
- Confucius
Post by Stab Frenzy » Sat Dec 25, 2010 7:36 am
I thought it might also be worth checking that the reset didn't turn Local Midi OFF. Check it and make sure it's ON.
