when a sound signal at any speed is thrown from left to right
n00b question srry ;(
What is this effect called?
- Sir Nose
- Real name: Bob
- Gear: Machinedrum, Octatrack, Moog LP, x0xb0x, Elka Solist 505, Simmons SDS-400
Re: What is this effect called?
panning
or
maybe a ping-pong effect
or
all that is good is nasty
- ninja6485
- Gear: Virus Ti, Jx-8p, Juno 60, Radias, Maschine, 101,303,606,707,727,808,909, odyssey, mirage, akai s5K/s2K/s1k, drumtraks, E6400ult, M1R, rx5, fizmo,d50
- Band: Subliminal Sea
the korg radias has an effect called rotary, which wirls the sound arround from left to right as though it were spinning arround you, or like a constant left to right wobble.
- Zamise
- Gear: Rollhand P00
- Band: Quantum-Source
An Auto Pan effect, or some Delay effects that can have dif left and right times can sort of do too, or one of my favs which is a Slice effect with different pan types.
- Synthaholic
- Expert Member
It depends on the effect...
If the sound repeats like an echo, going left, right, left right until it fades away, that's a ping-pong delay (example: tambourine sound in "Drive" by The Cars).
If it pans smoothly left to right and back (like a lot of EP/vibraphone sounds in the 70s and 80s), that is an auto-pan effect (example: "Babe" by Styx).
If there's some pitch shifting/phasing going on along with the panning (commonly used on organ sounds), that's a rotary speaker effect, also called a Leslie effect since it emulates the Leslie rotary speaker systems often used on Hammond and other organs. (many examples, Steppenwolf's "Born To Be Wild" comes readily to mind)
- cornutt
- Gear: 6th
Good points. One thing to add is that a rotary speaker might or might not have any left-right motion, depending on how they miked it up when it was recorded.
- gridsleep
- Real name: Kurt
- Gear: Das Vorlagengehirn
- Band: Big Steam Horse
Also the beginning of Pink Floyd's Us And Them.Synthaholic wrote:...(many examples, Steppenwolf's "Born To Be Wild" comes readily to mind)
The piano intro to "Echoes" was also run through a Leslie.
