Siel opera 6
Siel opera 6
Postby sam » Tue Feb 01, 2011 2:58 pm
I am restoring a opera 6....It had many problems that i have now fixed except it will not store to the memory and i need to know which chips on the logic board do this...?
Any pointers would be great.. :D
Lam memorymoog.Sonic six.Vp330 mk1.SH101.OSCar.ARP odyssey..multivox mx3000.Solina stringsynth.polivox
ms20/50.Andromeda. OBX.
Prophet 5 Pro-one. Wasp.EMS AKS.
sam
Re: Siel opera 6
Postby madtheory » Tue Feb 01, 2011 8:10 pm
Have you already downloaded data sheets for all the chips?
Band: madtheory
Re: Siel opera 6
Postby sam » Tue Feb 01, 2011 9:16 pm
madtheory wrote:Have you already downloaded data sheets for all the chips?
No .....But i am looking at changing the 4xxx chips to the right of the battery, The battery at some point has been changed but i see no damage to the board.
I also plan to change the e-proms.
sam
Re: Siel opera 6
Postby madtheory » Tue Feb 01, 2011 10:16 pm
Well the data sheets will tell you which one is the RAM...
Band: madtheory
Re: Siel opera 6
Postby sam » Wed Feb 02, 2011 8:33 am
madtheory wrote:Well the data sheets will tell you which one is the RAM...
Yes IC-5.....A little nudge has helped..
Cheers.
sam
Re: Siel opera 6
Postby madtheory » Wed Feb 02, 2011 10:43 am
A nudge on the chip? Cool, problem diagnosed.
Band: madtheory
Re: Siel opera 6
Postby sam » Wed Feb 02, 2011 1:07 pm
Again thank you...I will keep you updated.. :D
sam
Re: Siel opera 6
Postby sam » Wed Feb 02, 2011 5:51 pm
I have checked all the contacts around the chip and cleaned the pins...still the same but i keep on looking..
sam
Re: Siel opera 6
Postby madtheory » Wed Feb 02, 2011 6:07 pm
Could be the package is damaged. best to replace it.
Band: madtheory
Re: Siel opera 6
Postby sam » Sun Feb 06, 2011 8:29 pm
I have now fixed all the problems, Regarding the storing problem i found in the manual that you have to input 95 + enter to enable recording.
Never saw that one before.... :D
sam
Re: Siel opera 6
Postby madtheory » Sun Feb 06, 2011 8:59 pm
LOL! Glad it's all sorted. Interesting synth that one.
Band: madtheory
Re: Siel opera 6
Postby sam » Sun Feb 06, 2011 9:07 pm
Yes it's certainly a good synth, It has the sound of a prophet 5 i used to have.
It has very fast envelopes and the lfo's are super fast.
Next i will recap it and give it a good clean.
sam
Re: Siel opera 6
Postby sam » Sun Feb 06, 2011 9:21 pm
I am referring to a rev 2 p5 i had many years ago...This opera 6 has has ssm vco's even though it has dco writen on it.
The filter is sweet and deep.....I will be using this synth for time.. :D
sam
Re: Siel opera 6
Postby madtheory » Sun Feb 06, 2011 10:54 pm
sam wrote:Next i will recap it and give it a good clean.
Only the ones that are broken, right? Not all of them...
Band: madtheory
Re: Siel opera 6
Postby adamstan » Mon Feb 07, 2011 6:08 am
sam wrote:I am referring to a rev 2 p5 i had many years ago...This opera 6 has has ssm vco's even though it has dco writen on it.
Well - it is "DCO driven by VCO" :-) I probably repeat myself, but this is very interesting DCO design. Two SSM2031 VCOs are used as master oscillators for DCOs (instead of crystal oscillator or system clock).
adamstan
Real name: Adam
B5 DIY polysynth
KORG Poly61
Vermona DRM
Solton Programmer 24
LEMA EDD-5
Next
Return to HELP!
Users browsing this forum: Bing [Bot] and 1 guest
