Changing ESQ-1 Battery
elsquirrel
Post by elsquirrel » Tue Mar 15, 2011 12:24 pm
Anyone have any experience changing the battery on the model where the battery is all squished next to the sequencer cartridge:
Same deal as here: http://redfaux.typepad.com/the_redfaux_ ... -esq1.html Seems this person ended up taking it to a professional.
I have ok soldering skills and the battery ready to go. Any advice welcome.
thanks! 8-)
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: Changing ESQ-1 Battery
Post by rhino » Tue Mar 15, 2011 4:20 pm
I understand some have done it by cutting off the old battery tabs and soldering the new one right to the the 'stubs' still on the PC board. The old battery is soldered on the BACK SIDE of the pc board thru holes. I recommend the hard way: Remove the keyboard and the mainboard and solder the new tabs into the holes - from the rear.
- Confucius
rakk95
Gear: Ensoniq VFX, Ensoniq ESQ-1, Roland JV 880, Alesis QSR, Alesis Micron, Korg Polysix, Yamaha TX802
Post by rakk95 » Wed Mar 16, 2011 8:42 pm
+1...to really do it right, you need to remove the PCB and solder the battery to it from the underside. It's a pain in the rear, but it will ensure the battery is secure and that you don't drip solder on the topside components or accidentally hit something with the soldering iron.
I labeled all of the connectors with a Sharpie and took lots of photos before I started tearing things apart and had no issues.
elsquirrel
Post by elsquirrel » Thu Mar 17, 2011 5:49 am
Yep, I'll pick a day when I'm organised to do it and have a steady hand. I thought about not bothering as I don't really need to save sequences and it only effects the 40 internal patches, but I seeing as I have the battery just sitting here, it would be strange not to.
Good idea with the photos and sharpie.
