Fixing Juno-60 buttons / switches
mrosati
Post by mrosati » Wed May 18, 2011 12:04 am
Had some issues my Juno-60
- completely dead buttons
- intermittently working buttons
- it would randomly jump into manual mode for no known reason
Turns out the Juno-60 uses rubber-dome contact swtiches ( like a miniture PolySix key ) as opposed to the un-serviceable tact switches like in the Juno-106, TB-30 etc. These ones are easy to get at for cleaning & re-seating the rubber-dome. After cleaning up the metal contact with contact cleaner and a little scraping off of the c**p, gently using an eraser on the black conductive part of the rubber-dome & make sure the rubber-dome is re-seated properly, everything is working perfectly. Also doing this to the manual button seemed to solve that random problem.
Pix here:
http://s90.photobucket.com/albums/k270/ ... 0switches/
NOTE: Do NOT use contact cleaner on the black conductive part of the rubber-dome, it would make it worse. The rubber-dome is very thin & fragile, be very gentle when cleaning / handling it's very easy to rip apart.
Solderman
Re: Fixing Juno-60 buttons / switches
Post by Solderman » Wed May 18, 2011 12:50 am
I'm currently borrowing a Juno 60 that double-triggers some keys and randomly jumps between 2 octaves when the Octave Transpose switch(at left) is in the normal position. Would you say these are likely candidates for similar cleaning treatments? Since it isn't mine, I have not attempted to examine it yet. I haven't tried DCB yet either to isolate the problem to contact faults.
--Solderman no more.
EmptySet
Gear: MS20, x0xb0x, JV-1080, JX-3P, JX-8P(PG800), Juno Stage, VFX-SD, VL-1, ARP Omni I, D-50, DW6000
Post by EmptySet » Wed May 18, 2011 1:21 am
The 106 might have "unserviceable" tact switches, but they are replaceable with easy-to-find parts. (unlike the JX3P, which seems to be neither serviceable nor have parts available)
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Wed May 18, 2011 2:06 am
chipsforbrains (technology transplants) has a FEW N.O.S. JX3p switches left. About $4 each.
- Confucius
mrosati
Post by mrosati » Wed May 25, 2011 11:19 pm
Got this from my synth tech:
" That Juno 60 you are borrowing could have a problem with the switch itself maybe! If the switch is anything like those photos you sent me it should be an easy fix no? If its not that, could be a dying multiplexer just guessing. Just a quick look at the sm, IC9 (40H273) on panel board b, page 16 shows that it sends transposition data to the cpu from pin 5&2. This is taking it far though, I'd suspect controls before an IC though. "
