Fizmo Audio In
FX23
Fizmo Audio In
Post by FX23 » Tue Jul 26, 2011 5:53 pm
how does the fizmo audio in work? ive got a drum machine plugged into the input but im not hearing anysound?
balma
Real name: Mauricio
Re: Fizmo Audio In
Post by balma » Tue Jul 26, 2011 6:20 pm
Must go to the settings mode screen, scroll to the end, it says LIn (Line in) just turn it on and press save, otherwise it will return to Off when you turn off the Fizmo. Also you must move the thin knob that is next to the Line Input.
It's on the manual.
https://soundcloud.com/balma
FX23
Re: Fizmo Audio In
Post by FX23 » Tue Jul 26, 2011 8:15 pm
what is settings mode?
Psy_Free
Gear: Synths 'n' stuff.
Band: Klangzeit
Re: Fizmo Audio In
Post by Psy_Free » Tue Jul 26, 2011 8:46 pm
Press the MIDI button & scroll with the +/Yes until the LnL parameter is displayed. Then change the value.
Bandcamp 1
Bandcamp 2
Soundcloud
FX23
Re: Fizmo Audio In
Post by FX23 » Wed Jul 27, 2011 12:22 pm
thanks i tried that, the incomming sound seems to be only effected by the fizmo effects, is this correct?
Psy_Free
Band: Klangzeit
Re: Fizmo Audio In
Post by Psy_Free » Wed Jul 27, 2011 12:29 pm
Yes. Unless you use the vocoder insert effect, then the Fizmo patch sound will be shaped by the incoming signal.
Bandcamp 1
Bandcamp 2
Soundcloud
FX23
Re: Fizmo Audio In
Post by FX23 » Wed Jul 27, 2011 4:16 pm
Ok Thanks!
DLovas
Real name: David
Gear: Roland JP-8000
Roland JV-1080
Roland D-550
Roland S-760 (3x)
Waldorf Pulse+
u-he Zebra2
Re: Fizmo Audio In
Post by DLovas » Wed Nov 02, 2011 9:28 pm
just to resurrect this topic real quick - do you know if the Line in supports only MONO signals? or if i were to go out from the line source from a phones jack - would it then be able to take the stereo signal? I ask this because there is only one input jack on the fizmo's rear. Thanks
Syn-Fi
Re: Fizmo Audio In
Post by Syn-Fi » Thu Mar 06, 2014 12:58 pm
hi david,
did you discover the answer to this? I just wished to know myself without digging into the manual.
Gear List:
(1) Waldorf Q Yellow
(2) Waldorf Xtk
(3) Waldorf Pulse 2
(4) PPG Wave
(5) Oto Biscuit
(6) E-Mu E4XT & RFX32
Retired:
Access Virus Ti2 Polar
V-Synth
Ensoniq Fizmo
Ensoniq ESQ-M
Oberheim Matrix 1000
Waldorf Q+ (why, oh why?)
DLovas
Real name: David
Roland JV-1080
Roland D-550
Roland S-760 (3x)
Waldorf Pulse+
u-he Zebra2
Re: Fizmo Audio In
Post by DLovas » Fri May 16, 2014 2:26 am
Ah yes, I've learned that it is MONO.
