JX10 loading & dumping patchs via SYSEX.(not working)
iphoenix
Real name: Paul
Post by iphoenix » Sat Aug 06, 2011 11:24 pm
Does anyone have any tips about dumping & loading patches from & into the Roland JX10 ( unmodified) using Mac based librarians ?
I use SYSEX , which works well for all of my synths except for my Emu Ultraproteus & JX10 , apart from the earlier non midi ones.
I have tried various different buffer speeds but could not get it to load or save patches ( nor the Ultraproteus)
I have the MC64 in place with the protect switch set to 'off' & the 'protect' switch on the JX10 set to 'off ', 2 midi cables. Midisport 2x2 . G4 Powerbook 1.6 GHZ. SYSEX librarian.
Alex E
Gear: Jupiter-6, DX7, TX7, Juno-106, AX60, Pro One, S1000, M1r, Live 9, iMac MC309XX/A
Re: JX10 loading & dumping patchs via SYSEX.(not working)
Post by Alex E » Sun Aug 07, 2011 12:00 am
The JX10 has painfully incomplete MIDI implementation and there's no way of editing sounds over MIDI. I don't know why Roland rushed the firmware, but they did and it's really a shame.
A guy made an update you can buy, if that helps:
http://www.colinfraser.com/jx10/jx.htm
soundcloud.com/vectron
iphoenix
Real name: Paul
Post by iphoenix » Sun Aug 07, 2011 1:45 am
Thanks AlexE,
Im aware of the Colin Frasier Eprom mod . There is no way I would attempt to install a new Eprom in the JX10, its far too valuable a synth for me to lose if I made a mistake.
Im not interested in using midi for editing sounds on the JX10, as Im totally comfortable with using the alpha wheel / standard method , 1 parameter at a time which Ive been doing since 1993 when I first started programming it.
I wouldnt even be interested in a PG800 at a quarter the prices they go for.
gs
Post by gs » Mon Aug 08, 2011 2:39 pm
Be sure to check various MIDI settings in the menu-driven system itself, not just the hardware switches on synth and cartridge. I used to have a JX10 and successfully wrote the patch bank to sysex (and restored back to synth), but it's been a long time and I can't remember the exact steps. Also make sure the MIDI channel is set to 1.
Remember, you can only save/restore entire patch bank dumps, not individual patches (to my knowledge). The rack-mounted equivalent MKS-70 has a better MIDI implementation and allows live sysex editing as well as individual patch saving & retrieval.
iphoenix
Real name: Paul
Post by iphoenix » Mon Aug 08, 2011 10:28 pm
Thanks gs ,
yeah one day i will get a MKS70 or even a JX8P to back up my JX10.
Do you happen to remember what librarian you used to successfully load & back up your JX10 patches ?
Any chance you might also remember what buffer speeds you used?
loungedumore
Gear: iMac | iPad 2| iPad Air
Beatstep Pro | Mpx8
Volca bass, Keys ,beats
Monotribe | MS20 | SQ1
Minibrute | Midi4+
Graphite 49 | EIE
Band: Death By Media
Post by loungedumore » Tue Aug 09, 2011 12:59 pm
Might try with a different Midi interface if you have one around . I have had the 2X2 fail every synth I have owned at least once at several data speeds too .
Post by meatballfulton » Tue Aug 09, 2011 6:40 pm
Wasn't there some JX10 weirdness where you could only load/dump if you had a patch cart installed?
Ah, the "wild west" days of MIDI... :?
iphoenix
Real name: Paul
Post by iphoenix » Thu Aug 11, 2011 1:17 am
Yeah, the MC64 cartrige needs to be inserted in the JX10, before you can use the sequencer or sysex patch dumping or loading. I have one in place, but still have not managed to make a successful patch bank dump or load.
I have never had a problem with the Midisport since I upgraded the firmware, except for with the Emu Ultraproteus & the JX10, & Im not saying that its the midisport thats at fault. Im sure it isnt.
I dont have another midi interface yet anyway.
