Coffee spilled into the synth - what to expect?
vladimotor
Gear: V-Synth, Kurzweil PC3le6, Akai Miniak, Korg MicroX, Godin Solidac, Breedlove AC25, Live, Samplitude pro, Zebra, Z3ta, Imposcar, Absynth 4, FM8, Pro53
Post by vladimotor » Fri Oct 07, 2011 8:41 am
Just got a brand new keyboard and immediately spilled half a mug of black coffee(no sugar) into it :x :x :(
Any tips? Is it really bad? :( :( :(
White
Gear: Quite a few synths
Re: Coffee spilled into the synth - what to expect?
Post by White » Fri Oct 07, 2011 10:51 am
I shouldn't think so, but then I'm no expert (I've spilt coffee all over my computer once and it still works). Was it cheap coffee or expensive coffee?
Duncan J. White + quite a few synths
http://www.myspace.com/stickman76590059
vladimotor
Post by vladimotor » Fri Oct 07, 2011 11:40 am
Not an instant kind, really wonderful Colombian roast :cry:
Zamise
Gear: Rollhand P00
Band: Quantum-Source
Post by Zamise » Fri Oct 07, 2011 1:33 pm
yeah that is bad, you'll have to make another cup. Total waste of coffee.
Betterthanprozac
Gear: Junos, Tetra, Virus KC, MEK, Micron, YC-20, V synth, Triton, etc...
Band: Outer Space Real Estate
Post by Betterthanprozac » Fri Oct 07, 2011 2:49 pm
What kind of keyboard? I can assure that the Wurlitzer 200 is coffee ready. Beverages make synths behave funny though...as they say, give it 3 days or drop it from 3 feet to fix.
V301H
Band: The Characters
Post by V301H » Fri Oct 07, 2011 4:13 pm
Good thing there was no sugar in the coffee. Sugar could cause serious corrosion. You may have some permanent stains though.
cryabetes
Real name: Sam
Gear: Electribe Army: EA-1mkII, ER-1mkII, EM-1, ESX-1
Band: Cody P & Sammy B
Post by cryabetes » Fri Oct 07, 2011 5:18 pm
before powering it on, you may want to do the 'oh c**p the mobile was dropped in a puddle' thing, where you make an airtight environment (plastic) and have something hydrophilic like rice or baking soda or kitty litter inside said environ too to absorb the moisture and leave it for a few days. I'd just be careful not to uh fill your keyboard with rice or baking soda or whatever.
I recommend large sheets of plastic like they use for wrapping pallets. a local supermarket could probably hook you up with this.
Alex E
Gear: Jupiter-6, DX7, TX7, Juno-106, AX60, Pro One, S1000, M1r, Live 9, iMac MC309XX/A
Post by Alex E » Fri Oct 07, 2011 6:29 pm
What synthesizer was it?
I spilled a full cup on my macbook once. It turned itself off and I was 90% sure it was dead. I opened it up and cleaned the inside with paper towels and had a fan blow on it overnight. Seemed to do the trick.
When I got my phone wet and I was 90% that was dead too, I did the "take the battery out and keep it in rice" trick for several hours and it worked.
Hope isn't lost but there's no guarantee. Either way, you gotta start drying it out immediately.
soundcloud.com/vectron
Cumulus
Band: Cumulus
Post by Cumulus » Fri Oct 07, 2011 7:26 pm
You may notice that the internal clock runs fast for a while and then it will crash around 3:00 pm.
The next morning it will want more coffee.
Cumulus
Band: Cumulus
Post by Cumulus » Fri Oct 07, 2011 7:27 pm
Sorry to make light of your situation. Seriously, good luck with it. All of the previous advice is good. Make sure it's dry before you power it on.
Sir Ruff
Band: Ruff in the jungle
Post by Sir Ruff » Fri Oct 07, 2011 9:47 pm
Cumulus wrote:You may notice that the internal clock runs fast for a while and then it will crash around 3:00 pm.
:lol: :lol: :lol:
No, seriously, it may be a good idea to let it sit outside in the sun (covered of course)... that will help dry it out pretty quickly. Using another absorbent material like rice seems like a good idea, but I would imagine that might take a while on a keyboard.
you may want to open it up for the h**l of it and see what got soaked. Coffee does have a good amount of residue to it which could maybe affect things over time, so since you've already dunked it once, rinsing it off now with water or alcohol could prevent future issues... just a thought.
Do you even post on vse bro?
gd
Post by gd » Fri Oct 07, 2011 11:39 pm
Cool you have a new MS20 clone- Filtered Coffee, they are rare and highly desirable. :lol:
Prophet 08, Mini D, Radias, 2 x JD-990, Juno-60, 2 x JP-8080, Fantom X6, Speakeasy Stereo Rackmount Vintage Tube Preamp ...
cornutt
Gear: 6th
Post by cornutt » Sat Oct 08, 2011 4:58 am
Easy to fix. Spill some Red Bull and vodka on it. If that doesn't work, try cocaine.
Sir Ruff
Post by Sir Ruff » Sat Oct 08, 2011 5:14 am
cornutt wrote:If that doesn't work, try cocaine.
Probably easy enough to find depending on the age of the board!
atlantida
Gear: Yamaha: Motif ES-R, AN1X, CS6R, QY100
Korg: MS 2000-R
Post by atlantida » Mon Oct 10, 2011 2:12 pm
Great lesson there! lol If I were you - depending on time/will - I would open the synth and clean the keyboard/contacts.
Recently I got a Yamaha AN1X; I always open my used synths after purchase...and it was full of coffee rests, lol, so I cleaned it out and also cleaned and resoldered some circuits; it works well enough but sometimes it gives out some terrible cracking sounds before it warmed up. Hope you don't get any problems but it's always wise to take a look inside after such accident...(I use denatured alcohol for cleaning contacts; it worked always well)
Worked with:
Roland D50,JD800,XV3080,V-XT,MKS7
Yamaha FS1R,Motif ES R,CS6R,AN1X,AN200,TG500
Korg Trinity R,TritonR,EX8000,MS2000R,Radias
Novation Supernova 2R
Kawai K5000
DSI Mopho
Clavia NordLead1R
Ensoniq ESQ1,SQ80,MR
