fizmo psu
FX23
fizmo psu
Post by FX23 » Tue Nov 22, 2011 5:11 pm
hi, what polarity should i use on my psu to power up my fizmo?
garranimal
Re: fizmo psu
Post by garranimal » Tue Nov 22, 2011 6:19 pm
:shock: All synths are a little different: some need DC power and some need AC. The Fizmo requires 9V AC power supply rated for at least 1000mA current. Alternating-Current power supply into the Fizmo therefore doesn't require polarity. That's because the DC rectification happens inside the synth.
samuraipizzacat29
Real name: Nate
Re: fizmo psu
Post by samuraipizzacat29 » Fri Nov 25, 2011 10:16 pm
this should work (heck it's the one I just bought for my fizmo, so we're both getting fried if it's wrong):
As garranimal said, there's no polarity on an AC power supply.
FX23
Re: fizmo psu
Post by FX23 » Thu Aug 20, 2015 3:35 pm
the psu for my fizmo had the option of negative or positive, which one should i choose?
Re: fizmo psu
Post by meatballfulton » Thu Aug 20, 2015 3:37 pm
There is no negative and positive with AC!!
What is the supply you are using?
FX23
Re: fizmo psu
Post by FX23 » Thu Aug 20, 2015 4:13 pm
one that someone gave to me
Re: fizmo psu
Post by meatballfulton » Thu Aug 20, 2015 4:25 pm
So what's the output voltage and current rating? Is it AC or DC? See post above by garranimal.
FX23
Re: fizmo psu
Post by FX23 » Thu Aug 20, 2015 4:30 pm
its AC-AC
Re: fizmo psu
Post by meatballfulton » Thu Aug 20, 2015 5:05 pm
Then what do you mean by "positive" and "negative"?
AC doesn't have a +/- like DC does.
FX23
Re: fizmo psu
Post by FX23 » Thu Aug 20, 2015 5:14 pm
its a AC-AC adapter and you can choose between a positive tip or a negative tip
FX23
Re: fizmo psu
Post by FX23 » Thu Aug 20, 2015 7:21 pm
FX23
Re: fizmo psu
Post by FX23 » Fri Aug 21, 2015 10:01 pm
what happens next?
Yekuku
Re: fizmo psu
Post by Yekuku » Fri Aug 21, 2015 10:14 pm
As meatballfulton said, AC power supplies have no polarity.
Obviously the power supply you have is not original and probably it has a generic enclosure that Chinese manufacturers use for both AC and DC psu's.
Whatever the polarity is set, it will work.
It is all about sharing...
