Repairing a Rom Chip
GameChanger
Gear: MPC60
Post by GameChanger » Sat Dec 03, 2011 5:33 am
HI Guys, Im not the most technical when it comes to repairs. Is it possible and is it tough to repair this rom chip? Could a quick solder job do the trick?
Yekuku
Re: Repairing a Rom Chip
Post by Yekuku » Sat Dec 03, 2011 11:25 am
If you are talking about the broken pin, you dont have to worry thats an easy fix.
You can solder a wire there, just make sure that the wire fits the eprom socket first.
Also try not to heat the eprom too much.
Here is an example of an eprom that had one pin completely broken off:
It is all about sharing...
GameChanger
Gear: MPC60
Post by GameChanger » Sat Dec 03, 2011 5:40 pm
Sweet thanks I appreciate it. Can I use standard partial lead solder wire?
Yekuku
Post by Yekuku » Sat Dec 03, 2011 10:20 pm
hmm, no i would not recommend solder wire because it can be bend easily, it needs to be more rigid.
If you are out of ideas , try a staple.
It is good to tin both parts before soldering.
snod_donkey
Post by snod_donkey » Sun Dec 04, 2011 10:58 am
Use the leg off a resistor or small diode. They are all ready tinned and easy to use as well as easy to shape if required
