How to tune Korg Micro Preset M500
Posted: Thu Dec 15, 2011 5:37 pm
by snod_donkey
Just picked up a Micro Preset m500 but it wants a bit of a tune up
I cant find any set up info on how to set the volts per octave (if thats what it uses) or which trimmers to use.
If i set A to 440 hz and then press a note one or two octaves up or down the scale is not tracking correctly. Looked at the circuits but the quality is so bad i cant work out whats what
Any help would be great...
Re: How to tune Korg Micro Preset M500
Posted: Fri Dec 16, 2011 10:00 pm
by gearfixer
snod_donkey wrote:Just picked up a Micro Preset m500 but it wants a bit of a tune up
PMed
Posted: Tue Mar 17, 2020 7:56 am
by gkmaia
This is quite an old post, but will see if I can revive it.
I finally finished fixing my M500 and now stumbling on how to tune it. My biggest problem is that I am out of range.
Vr1 seems to be a secondary VCO tune from keyboard
Vr2 tunes the VCO (frequency)
Vr3 tunes the trigger, but also affects frequency
Vr1,2,3 combines intends to tune octave 2"
Vr4 & 5 adjust the white & pink noise volumes
Vr7, 8, 9 & 10 tune the octaves 4,8,16,32 respectively
If I set the Pitch knob to "0" I should be able to by adjusting Vr1,2&3 get a C note on octave 2" close to tune and then use Vr7 to 10 just to fine tune the octaves.
But that is now what happens, even lowering down Vr 1 to 3 I still above a C.
I could change VCO's R27 & 28 to a lower value to force the opamp to a lower pitch but not sure if changing the circuit is the way to go.
What you guys suggest?
